(2020-05-07, 20:11)Javier Orquera Wrote: [ -> ]Hello to all.
First, if this post are wrong placed, move it to the proper place.
I made several changes to the part 32289b.dat (that I'm working on), so I attach the files with other numbers and new ones:
1) 32289bs01a.dat: modified with battery form and placeholder to the rear axle
2) u9510a.dat: the idea is to substitute the one in the PT.
3) 13.dat: new file; number and name are with the purpose to identify it, so you can suggest new ones. Also, it is my mane target.
4) 32289b_a: these one have bottom inside to the battery form and the concavity for part 914.dat (I am thinking if leave it as the original submitted or these one; what do you think? Comment)
I decide these before I change the original files in case you dislike the changes and the new parts.
Hi Javier,
* I see you closed the gaps at the pin holes on the very end. Good job!
* The battery box looks good ... I'm not sure if trying to use box primitives wherever you can and on the downside creating T-junctions is the right way.
* Unfortunately this part came with a lot of issues. Please check the overlaps at:
4 4 -46 90.999912232 0 -46 90.315150136 -3.444175152 -60 90.315150136 -3.444175152 -60 90.999912232 0
4 4 -46 90.315150136 -3.444175152 -46 88.36396 -6.36396 -60 88.36396 -6.36396 -60 90.315150136 -3.444175152
4 4 -60 91.000057896 0 -60 90.3149419237 -3.4441060649 -60 89.3910359175 -3.0614197565 -60 90.0000671766 0
4 4 -60 90.3149419237 -3.4441060649 -60 88.363963 -6.363963 -60 87.656856 -5.656856 -60 89.3910359175 -3.0614197565
4 4 -58 89.3912 -3.0616 -58 87.6568 -5.6568 -60 87.6568 -5.6568 -60 89.3912 -3.0616
4 4 -58 87.6568 -5.6568 -58 85.0616 -7.3912 -60 85.0616 -7.3912 -60 87.6568 -5.6568
3 4 -60 89 -8 -60 85.04 -7.36 -60 87.6 -5.6
3 4 -60 89 -8 -60 87.6 -5.6 -60 89 -5.28
3 4 -60 89 -5.28 -56.34 90.28 -3.42 -56.34 90.28 -5.28
4 4 -56.34 90.28 -3.42 -46 90.28 -3.42 -46 90.28 -5.28 -56.34 90.28 -5.28
Also with the edges. As a starting point I would substitute the 1-4cyli.dat with:
1 16 -60 82 0 0 14 0 8.31491 0 3.44415 3.44415 0 -8.31491 1-8cylo.dat
1 16 -60 82 0 0 1 0 .92388 0 .38268 .38268 0 -.92388 1-8ring8.dat
And rebuild the rest accordingly.
* This looks rather strange:
1 1 0 80.5 37.7 -10 0 0 0 0 10 0 3.1 0 1-4cylo.dat
1 1 0 80.5 37.7 -10 0 0 0 0 10 0 1 0 1-4ndis.dat
1 1 0 80.5 40.8 -10 0 0 0 0 10 0 -1 0 1-4ndis.dat
1 1 0 80.5 37.7 0 0 -1 1 0 0 0 1 0 1-4ring9.dat
1 1 0 80.5 40.8 0 0 -1 1 0 0 0 -1 0 1-4ring9.dat
1 1 0 80.5 37.7 0 0 -9 9 0 0 0 1 0 1-4edge.dat
1 1 0 80.5 52.9 -10 0 0 0 0 10 0 3.1 0 1-4cylo.dat
1 1 0 80.5 52.9 -10 0 0 0 0 10 0 1 0 1-4ndis.dat
1 1 0 80.5 52.9 0 0 -1 1 0 0 0 1 0 1-4ring9.dat
The walls have no "thickness".
My proposal of "unification", second part:
0 ~Electric Technic Motor 4.5V 6 x 17 x 5 - Main Half Base Type 2
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 Name: 32289bs01.dat[/size][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 BFC CERTIFY CCW[/size][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]4 16 -22 76 56 -22 76 60 -40 76 60 -36 76 56[/size][/font][/size][/color]
1 16 -32.8 82 40 0 -7.2 0 -6.365 0 -6.365 -6.365 0 6.365 1-4cylo.dat
4 16 -32.8 73.69 36.5579 -32.8 50.2969 36.5634 -32.8 51.001383 40 -32.8 72.998617 40
4 16 -32.8 50.2969 43.4366 -32.8 73.683491 43.444738 -32.8 72.998617 40 -32.8 51.001383 40
4 16 -32.8 50.2969 36.5634 -32.8 73.69 36.5579 -32.8 75.65 33.65 -32.8 48.35 33.65
4 16 -32.8 73.683491 43.444738 -32.8 50.2969 43.4366 -32.8 48.35 46.35 -32.8 75.65 46.35
4 16 -40 42 31 -40 45.4443 31.6849 -40 78.5557 31.6849 -40 76 31
3 16 -40 76 31 -40 78.5557 31.6849 -40 82 31
4 16 -40 78.56 31.69 -40 45.4443 31.69 -40 48.3639 33.6361 -40 75.6361 33.6361
4 16 -40 42 49 -40 76 49 -40 78.5557 48.3151 -40 45.4443 48.3151
3 16 -40 76 49 -40 82 49 -40 78.5557 48.3151
4 16 -40 78.5557 48.3151 -40 75.635 46.365 -40 48.3639 46.3639 -40 45.4443 48.3151
1 16 -32.8 42 40 0 -7.2 0 6.365 0 6.365 -6.365 0 6.365 1-4cylo.dat
4 16 -32.8 48.365 33.635 -32.8 75.635 33.635 -40 75.635 33.635 -40 48.3639 33.6361
4 16 -40 75.635 46.365 -32.8 75.635 46.365 -32.8 48.35 46.35 -40 48.3639 46.3639
4 16 -22 51 31 -22 73 31 -22 73 40 -22 51 40
4 16 -22 51 40 -22 73 40 -22 73 49 -22 51 49
1 16 -22 82 40 0 -1 0 0 0 2 2 0 0 4-4ring3.dat
1 16 -22 82 40 0 -1 0 0 0 1 -1 0 0 4-4ring8.dat
1 16 -22 82 40 0 -1 0 0 0 -9 -9 0 0 2-4ndis.dat
1 16 -22 82 40 0 -1 0 0 0 9 -9 0 0 7-16ndis.dat
3 16 -22 91 49 -22 88.4 49 -22 85.4443 48.3151
3 16 -22 85.4443 48.3151 -22 88.4 49 -22 82 49
4 16 0 96 26 0 96 -24 -16 96 -24 -26 96 34.4566
4 16 0 96 26 -26 96 34.4566 -26 96 42 -16.5 96 42
4 16 -6.5 96 42 0 96 37.7 0 96 26 -11.5 96 42
3 16 -16.5 96 42 -11.5 96 42 0 96 26
3 16 0 96 37.7 -6.5 96 42 -6.5 96 47
3 16 -6.5 96 52 -11.5 96 52 0 96 60
4 16 0 96 60 -11.5 96 52 -16.5 96 52 -22 96 60
4 16 -26 96 45.5434 -26 96 60 -22 96 60 -16.5 96 52
4 16 0 96 37.7 -6.5 96 47 -6.5 96 52 0 96 60
3 16 -16.5 96 47 -26 96 45.5434 -16.5 96 52
4 16 -16.5 96 42 -26 96 42 -26 96 45.5434 -16.5 96 47
4 16 -37 88 60 -40 76 60 -22 76 60 -26 88 60
3 16 -40 76 60 -37 88 60 -40 88 60
4 16 -26 88 60 -22 76 60 -22 92 60 -26 96 60
4 16 0 92 60 0 96 60 -22 96 60 -22 92 60
3 16 -22 96 60 -26 96 60 -22 92 60
4 16 -16 96 -24 -40 96 -24 -40 96 10 -26 96 34.4566
1 16 -11.5 92 47 0 0 -7.5 0 1 0 7.5 0 0 4-4ndis.dat
1 16 -11.5 96 47 0 0 -5 0 -1 0 5 0 0 4-4ndis.dat
4 16 -11.5 92 26 -11.5 92 37.7 -22 92 37.7 -22 92 31
4 16 -6.55 92 26 -6.55 92 37.7 -11.5 92 37.7 -11.5 92 26
1 16 0 92 26 0 0 -6.55 4 0 0 0 11.7 0 1-4cylo.dat
1 16 0 92 26 0 0 -6.55 4 0 0 0 -1 0 1-4disc.dat
1 16 0 92 37.7 0 0 -6.55 4 0 0 0 1 0 1-4disc.dat
4 16 -11.5 92 26 -11.5 76.673 26 -4.63 83 26 -6.55 92 26
4 16 0 83 26 0 92 26 -6.55 92 26 -4.63 83 26
3 16 -4.63 76.6732 26 -4.63 83 26 -11.5 76.673 26
4 16 -4.63 83 22 -11.5 76.673 22 -11.5 92 22 -4.63 92 22
3 16 -4.63 76.6732 22 -11.5 76.673 22 -4.63 83 22
4 16 0 83 22 -4.63 83 22 -4.63 92 22 0 92 22
4 16 -11.5 92 22 -11.5 76.673 22 -11.5 76.673 26 -11.5 92 26
4 16 -11.5 76.673 26 -11.5 76.673 22 -4.63 76.6732 22 -4.63 76.6732 26
4 16 -4.63 83 26 -4.63 76.6732 26 -4.63 76.6732 22 -4.63 83 22
4 16 0 83 26 -4.63 83 26 -4.63 83 22 0 83 22
4 16 -19 92 39.5 -22 92 37.7 -11.5 92 37.7 -11.5 92 39.5
3 16 -11.5 92 39.5 -11.5 92 37.7 -6.55 92 37.7
4 16 0 92 37.7 -4 92 39.5 -11.5 92 39.5 -6.55 92 37.7
3 16 -22 92 60 -19 92 54.5 -11.5 92 54.5
4 16 -22 92 60 -11.5 92 54.5 -4 92 54.5 0 92 60
4 16 -22 92 60 -22 92 37.7 -19 92 39.5 -19 92 47
3 16 -22 92 60 -19 92 47 -19 92 54.5
4 16 -4 92 47 -4 92 39.5 0 92 37.7 0 92 60
3 16 -4 92 47 0 92 60 -4 92 54.5
4 16 -22 85.6 56 -22 88.4 49 -22 91 49 -22 92 60
4 16 -22 76 60 -22 76 56 -22 85.6 56 -22 92 60
3 16 -40 96 10 -37 96 34.4566 -26 96 34.4566
4 16 -26 96 45.5434 -26 93.78262 45.5434 -26 88 60 -26 96 60
4 16 -22 91 31 -22 92 31 -22 92 37.7 -22 91 40
4 16 -22 91 49 -22 91 40 -22 92 37.7 -22 92 60
4 16 -37 90.2426 44.2426 -37 88.2962 45.5434 -26 88.2962 45.5434 -26 90.2426 44.2426
4 16 -37 90.2426 44.2426 -26 90.2426 44.2426 -26 91.5434 42.2962 -37 91.5434 42.2962
4 16 -37 91.5434 42.2962 -26 91.5434 42.2962 -26 92 40 -37 92 40
4 16 -37 92 40 -26 92 40 -26 91.5434 37.7038 -37 91.5434 37.7038
4 16 -37 91.5434 37.7038 -26 91.5434 37.7038 -26 90.2426 35.7574 -37 90.2426 35.7574
4 16 -26 90.2426 35.7574 -26 88.2962 34.4566 -37 88.2962 34.4566 -37 90.2426 35.7574
4 16 -36 92 8 -32 92 13 -34 92 30 -36 92 30
4 16 -34 92 30 -32 92 13 -11.5 92 22 -22 92 31
3 16 -32 92 13 -16 92 13 -11.5 92 22
4 16 -4.63 92 22 -11.5 92 22 -16 92 13 0 92 13
3 16 0 92 22 -4.63 92 22 0 92 13
3 16 -11.5 92 26 -22 92 31 -11.5 92 22
3 16 -32 92 0 -36 92 8 -32 92 -13
3 16 -36 92 8 -32 92 0 -32 92 13
4 16 -40 92 -13 -32 92 -13 -36 92 8 -40 92 8
3 16 -22 92 31 -34 92 31 -34 92 30
3 16 -37 96 34.4566 -37 92 40 -37 91.5434 37.7038
3 16 -37 91.5434 37.7038 -37 90.2426 35.7574 -37 96 34.4566
3 16 -37 90.2426 35.7574 -37 88.2962 34.4566 -37 96 34.4566
3 16 -37 93.78262 45.5434 -37 91.5434 42.2962 -37 92 40
3 16 -37 93.78262 45.5434 -37 90.2426 44.2426 -37 91.5434 42.2962
3 16 -37 90.2426 44.2426 -37 93.78262 45.5434 -37 88.2962 45.5434
3 16 -26 91.5434 37.7038 -26 92 40 -26 96 34.4566
3 16 -26 90.2426 35.7574 -26 91.5434 37.7038 -26 96 34.4566
3 16 -26 90.2426 35.7574 -26 96 34.4566 -26 88.2962 34.4566
3 16 -26 93.78262 45.5434 -26 92 40 -26 91.5434 42.2962
3 16 -26 93.78262 45.5434 -26 91.5434 42.2962 -26 90.2426 44.2426
3 16 -26 90.2426 44.2426 -26 88.2962 45.5434 -26 93.78262 45.5434
3 16 -26 96 42 -26 96 34.4566 -26 92 40
4 16 -26 96 45.5434 -26 96 42 -26 92 40 -26 93.78262 45.5434
4 16 -40 96 10 -40 96 40 -37 96 40 -37 96 34.4566
3 16 -37 96 34.4566 -37 96 40 -37 92 40
4 16 -37 96 40 -40 96 40 -40 88 60 -37 93.78262 45.5434
3 16 -40 88 60 -37 88 60 -37 93.78262 45.5434
4 16 -26 96 34.4566 -37 96 34.4566 -37 88.2962 34.4566 -26 88.2962 34.4566
3 16 -37 92 40 -37 96 40 -37 93.78262 45.5434
4 16 -37 88.2962 45.5434 -37 93.78262 45.5434 -26 93.78262 45.5434 -26 88.2962 45.5434
4 16 -37 88 60 -26 88 60 -26 93.78262 45.5434 -37 93.78262 45.5434
1 16 -11.5 90 47 0 0 7.5 0 2 0 7.5 0 0 4-4cylo.dat
1 16 -11.5 90 47 0 0 1.25 0 1 0 1.25 0 0 4-4ring3.dat
1 16 -11.5 90 47 0 0 1.25 0 1 0 1.25 0 0 4-4ring2.dat
1 16 -11.5 90 47 0 0 2.5 0 1 0 2.5 0 0 4-4ring2.dat
1 16 -11.5 90 47 0 0 -2.5 0 4 0 2.5 0 0 4-4cylo.dat
1 16 -11.5 94 47 0 0 5 0 2 0 5 0 0 4-4cylo.dat
1 16 -11.5 92 47 0 0 5 0 2 0 5 0 0 4-4cylo.dat
1 16 -11.5 94 47 0 0 1.25 0 -1 0 1.25 0 0 4-4ring3.dat
1 16 -11.5 94 47 0 0 1.25 0 -1 0 1.25 0 0 4-4ring2.dat
4 16 -16 92 0 0 92 -13 0 92 13 -16 92 13
3 16 -16 92 0 -16 92 -13 0 92 -13
0
2 24 -36 92 8 -40 92 8
2 24 -36 92 30 -36 92 8
2 24 -34 92 30 -36 92 30
2 24 -34 92 31 -22 92 31
2 24 -22 92 31 -22 91 31
2 24 -22 82 31 -22 91 31
2 24 -22 73 31 -22 82 31
2 24 -22 73 31 -22 51 31
2 24 -34 92 31 -34 92 30
2 24 -22 76 60 -22 92 60
2 24 -22 76 60 -40 76 60
2 24 0 92 60 -22 92 60
2 24 -22 92 31 -22 92 60
2 24 -6.55 92 37.7 -6.55 92 26
2 24 -6.55 92 37.7 0 92 37.7
2 24 -11.5 92 26 -11.5 76.673 26
2 24 -11.5 92 26 -6.55 92 26
2 24 -6.55 92 26 0 92 26
2 24 -11.5 92 22 -11.5 92 26
2 24 -11.5 92 22 -11.5 76.673 22
2 24 -11.5 92 22 0 92 22
2 24 -11.5 76.673 22 -11.5 76.673 26
2 24 -4.63 76.6732 22 -11.5 76.673 22
2 24 -4.63 76.6732 26 -11.5 76.673 26
2 24 -4.63 76.6732 22 -4.63 76.6732 26
2 24 -4.63 83 22 -4.63 76.6732 22
2 24 -4.63 83 26 -4.63 76.6732 26
2 24 -4.63 83 22 -4.63 83 26
2 24 -4.63 83 26 0 83 26
2 24 -4.63 83 22 0 83 22
2 24 -36 76 56 -22 76 56
2 24 -22 76 56 -22 85.6 56
2 24 -22 88.4 49 -22 85.6 56
2 24 -22 88.4 49 -22 82 49
2 24 -22 73 49 -22 82 49
2 24 -22 73 49 -22 51 49
2 24 -26 96 34.4566 -26 96 60
2 24 -26 93.78262 45.5434 -26 88 60
2 24 -26 88 60 -26 96 60
2 24 0 96 60 -26 96 60
2 24 -40 96 40 -40 88 60
2 24 -26 96 34.4566 -37 96 34.4566
2 24 -26 88 60 -37 88 60
2 24 -37 88 60 -40 88 60
2 24 -40 76 60 -40 88 60
2 24 -37 96 34.4566 -37 96 40
2 24 -37 93.78262 45.5434 -26 93.78262 45.5434
2 24 -37 93.78262 45.5434 -37 96 40
2 24 -26 88.2962 45.5434 -26 93.78262 45.5434
2 24 -26 88.2962 45.5434 -37 88.2962 45.5434
2 24 -26 88.2962 34.4566 -37 88.2962 34.4566
2 24 -26 88.2962 34.4566 -26 96 34.4566
2 24 -37 88.2962 34.4566 -37 96 34.4566
2 24 -37 88.2962 45.5434 -37 93.78262 45.5434
2 24 -37 88.2962 45.5434 -37 90.2426 44.2426
2 24 -37 91.5434 42.2962 -37 90.2426 44.2426
2 24 -37 91.5434 42.2962 -37 92 40
2 24 -37 92 40 -37 91.5434 37.7038
2 24 -37 91.5434 37.7038 -37 90.2426 35.7574
2 24 -37 90.2426 35.7574 -37 88.2962 34.4566
2 24 -26 88.2962 45.5434 -26 90.2426 44.2426
2 24 -26 91.5434 42.2962 -26 90.2426 44.2426
2 24 -26 91.5434 42.2962 -26 92 40
2 24 -26 92 40 -26 91.5434 37.7038
2 24 -26 91.5434 37.7038 -26 90.2426 35.7574
2 24 -26 90.2426 35.7574 -26 88.2962 34.4566
2 24 -40 42 49 -40 76 49
2 24 -40 48.3639 46.3639 -40 75.635 46.365
2 24 -40 48.3639 33.6361 -40 75.6361 33.6361
2 24 -40 42 31 -40 76 31
2 24 -32.8 48.35 33.65 -32.8 75.65 33.65
2 24 -32.8 75.65 46.35 -40 75.635 46.365
2 24 -32.8 75.65 33.65 -40 75.6361 33.6361
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]2 24 -32.8 48.35 46.35 -32.8 75.65 46.35[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]------------------------------------------------------------------[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 ~Electric Technic Motor 4.5V 6 x 17 x 5 Concavity for Axle Gear Base Type 2[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 Name: 32289bs02.dat[/size][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 BFC INVERTNEXT[/size][/font][/size][/color]
1 16 -32 92 0 0 16 0 0 0 4 13 0 0 2-4cylo.dat
1 16 -32 92 0 0 -1 0 0 0 4 13 0 0 2-4disc.dat
1 16 -16 92 0 0 1 0 0 0 4 13 0 0 2-4disc.dat
2 24 -16 92 -13 -32 92 -13
2 24 -32 92 0 -32 92 13
2 24 -16 92 13 -32 92 13
2 24 -16 92 -13 -16 92 0
2 24 -32 92 0 -32 92 -13
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]2 24 -16 92 0 -16 92 13[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]------------------------------------------------------------------[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 ~Electric Technic Motor 4.5V 6 x 17 x 5 Base Type 1[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 Name: 32289a.dat[/size][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]1 16 0 0 0 1 0 0 0 1 0 0 0 1 32289s01.dat[/size][/font][/size][/color]
1 16 0 0 0 1 0 0 0 1 0 0 0 1 32289as01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 32289as02.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 32289s01.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 32289as01.dat
0
1 16 8 96 -30 0 0 8 0 -1 0 -6 0 0 box4-4a.dat
1 16 -8 96 -30 0 0 -8 0 -1 0 -6 0 0 box4-4a.dat
1 16 0 93 -48 0 8 0 1 0 0 0 0 5 box3u4a.dat
1 16 0 93 -48 0 -8 0 1 0 0 0 0 5 box3u4a.dat
4 16 0 88 -220 -40 88 -220 -40 88 -216 16 88 -216
4 16 20 88 -216 40 88 -216 40 88 -220 0 88 -220
3 16 16 88 -216 20 88 -216 0 88 -220
4 16 16 88 -216 -40 88 -216 -40 84 -216 16 84 -216
4 16 -40 84 -212 -20 84 -212 16 84 -216 -40 84 -216
3 16 16 84 -212 16 84 -216 -20 84 -212
4 16 40 88 -216 20 88 -216 20 84 -216 40 84 -216
4 16 20 84 -212 40 84 -212 40 84 -216 20 84 -216
3 16 16 84 -212 -20 84 -212 -20 82 -212
4 16 -20 82 -212 -16 64 -212 -6.1232 64 -212 16 84 -212
4 16 16 84 -212 -6.1232 64 -212 0 64 -212 16 65.875 -212
3 16 16 65.875 -212 0 64 -212 6.1232 64 -212
3 16 16 65.875 -212 6.1232 64 -212 16 64 -212
3 16 -20 82 -212 -20 64 -212 -16 64 -212
2 24 0 88 -220 -40 88 -220
2 24 40 88 -220 0 88 -220
2 24 16 88 -216 -40 88 -216
2 24 20 88 -216 40 88 -216
2 24 16 84 -216 -40 84 -216
2 24 16 84 -212 -40 84 -212
2 24 40 84 -216 20 84 -216
2 24 40 84 -212 20 84 -212
3 16 16 92 -13 32 92 -13 32 92 0
3 16 16 92 -13 32 92 0 16 92 13
3 16 16 92 13 32 92 0 32 92 13
4 16 13 96 -14.85 13 96 14.85 35 96 14.85 35 96 -14.85
1 16 0 64 -212 16 0 0 0 0 -16 0 2.875 0 3-16cylo.dat
1 16 36 64 -212 -16 0 0 0 0 -16 0 2.875 0 3-16cylo.dat
3 16 6.1232 65.875 -205.125 6.1232 49.2176 -205.125 11.3136 52.6864 -205.125
3 16 6.1232 65.875 -205.125 11.3136 52.6864 -205.125 14.7824 57.8768 -205.125
3 16 6.1232 65.875 -205.125 14.7824 57.8768 -205.125 16 64 -205.125
3 16 6.1232 65.875 -205.125 16 64 -205.125 16 65.875 -205.125
4 16 25.8768 65.875 -205.125 20 65.875 -205.125 20 64 -205.125 21.2176 57.8768 -205.125
4 16 25.8768 65.875 -205.125 21.2176 57.8768 -205.125 24.6864 52.6864 -205.125 25.8768 51.89084 -205.125
1 16 18 64 -205.125 2 0 0 0 0 1.875 0 -1 0 2-4ndis.dat
3 16 29.8768 65.875 -209.125 29.8768 49.2176 -209.125 24.6864 52.6864 -209.125
4 16 21.2176 57.8768 -209.125 20 64 -209.125 20 65.875 -209.125 25.8768 65.875 -209.125
4 16 24.6864 52.6864 -209.125 21.2176 57.8768 -209.125 25.8768 65.875 -209.125 29.8768 65.875 -209.125
3 16 6.1232 49.2176 -209.125 6.1232 65.875 -209.125 11.3136 52.6864 -209.125
3 16 11.3136 52.6864 -209.125 6.1232 65.875 -209.125 14.7824 57.8768 -209.125
3 16 14.7824 57.8768 -209.125 6.1232 65.875 -209.125 16 64 -209.125
3 16 16 64 -209.125 6.1232 65.875 -209.125 16 65.875 -209.125
4 16 29.8768 49.2176 -209.125 29.8768 65.875 -209.125 29.8768 65.875 -205.125 29.8768 51.89084 -205.125
3 16 29.8768 49.2176 -205.125 29.8768 49.2176 -209.125 29.8768 51.89084 -205.125
4 16 6.1232 65.875 -205.125 6.1232 65.875 -209.125 6.1232 49.2176 -209.125 6.1232 49.2176 -205.125
1 16 27.8768 76.9375 -205.125 2 0 0 0 0 11.0625 0 4 0 box4-7a.dat
4 16 29.8768 51.89084 -201.125 29.8768 51.89084 -205.125 29.8768 65.875 -205.125 29.8768 65.875 -201.125
4 16 25.8768 51.89084 -201.125 29.8768 51.89084 -201.125 29.8768 65.875 -201.125 25.8768 65.875 -201.125
4 16 25.8768 51.89084 -201.125 25.8768 65.875 -201.125 25.8768 65.875 -205.125 25.8768 51.89084 -205.125
3 16 29.8768 49.2176 -201.125 29.8768 51.89084 -201.125 25.8768 51.89084 -201.125
4 16 29.8768 51.89084 -201.125 29.8768 49.2176 -201.125 29.8768 49.2176 -205.125 29.8768 51.89084 -205.125
1 16 16 76.9375 -207.125 0 -9.8768 0 0 0 11.0625 2 0 0 box4-7a.dat
1 16 27.8768 76.9375 -207.125 2 0 0 0 11.0625 0 0 0 -2 box3-9a.dat
4 16 16 84 -212 16 65.875 -212 16 65.875 -209.125 16 88 -209.125
3 16 16 88 -212 16 84 -212 16 88 -209.125
3 16 16 88 -212 16 88 -209.125 18 88 -209.125
3 16 16 88 -212 18 88 -209.125 20 88 -212
3 16 20 88 -212 18 88 -209.125 20 88 -209.125
3 16 20 88 -209.125 20 84 -212 20 88 -212
4 16 20 82 -212 20 88 -209.125 20 65.875 -209.125 20 64 -212
3 16 20 84 -212 20 88 -209.125 20 82 -212
1 16 18 84 -214 0 0 2 0 4 0 -2 0 0 box3u6.dat
3 16 20 65.875 -209.125 20 64 -209.125 20 64 -212
1 16 16 64.9375 -210.5625 0 1 0 0.9375 0 0 0 0 1.4375 rect2p.dat
1 16 22.9384 65.875 -207.125 2.9384 0 0 0 22.125 0 0 0 2 box3u10p.dat
1 16 17 76.9375 -207.125 1 0 0 0 11.0625 0 0 0 2 box2-11.dat
1 16 19 76.9375 -207.125 1 0 0 0 11.0625 0 0 0 2 box2-11.dat
2 24 16 88 -209.125 16 65.875 -209.125
2 24 29.8768 49.2176 -209.125 29.8768 65.875 -209.125
2 24 16 65.875 -212 16 84 -212
2 24 20 64 -212 20 82 -212
2 24 20 82 -212 20 84 -212
2 24 20 65.875 -209.125 20 88 -209.125
2 24 20 65.875 -209.125 20 64 -209.125
2 24 6.1232 49.2176 -205.125 6.1232 65.875 -205.125
2 24 6.1232 49.2176 -209.125 6.1232 65.875 -209.125
2 24 29.8768 49.2176 -201.125 29.8768 51.89084 -201.125
2 24 29.8768 49.2176 -205.125 29.8768 49.2176 -201.125
2 24 25.8768 51.89084 -201.125 29.8768 49.2176 -201.125
2 24 25.8768 51.89084 -201.125 25.8768 51.89084 -205.125
2 24 25.8768 65.875 -205.125 25.8768 88 -205.125
2 24 25.8768 51.89084 -205.125 25.8768 65.875 -205.125
2 24 25.8768 51.89084 -201.125 25.8768 65.875 -201.125
2 24 29.8768 51.89084 -201.125 29.8768 65.875 -201.125
2 24 20 88 -212 20 88 -209.125
2 24 16 88 -212 16 88 -209.125
1 16 -36 64 -212 16 0 0 0 0 -16 0 2.875 0 3-16cylo.dat
1 16 0 64 -212 -16 0 0 0 0 -16 0 2.875 0 3-16cylo.dat
1 16 -20 76.9375 -207.125 0 -9.8768 0 0 0 11.0625 2 0 0 box4-7a.dat
1 16 -18 76.9375 -207.125 2 0 0 0 11.0625 0 0 0 -2 box2-11.dat
3 16 -20 65.875 -205.125 -18 65.875 -205.125 -20 88 -205.125
3 16 -20 88 -205.125 -18 65.875 -205.125 -16 88 -205.125
3 16 -16 88 -205.125 -18 65.875 -205.125 -16 65.875 -205.125
1 16 -16 76.9375 -207.125 0 9.8768 0 0 0 11.0625 2 0 0 box4-7a.dat
1 16 -18 64 -205.125 2 0 0 0 0 1.875 0 -1 0 2-4ndis.dat
3 16 -29.8768 65.875 -205.125 -29.8768 49.2176 -205.125 -24.6864 52.6864 -205.125
3 16 -29.8768 65.875 -205.125 -24.6864 52.6864 -205.125 -21.2176 57.8768 -205.125
3 16 -29.8768 65.875 -205.125 -21.2176 57.8768 -205.125 -20 64 -205.125
3 16 -29.8768 65.875 -205.125 -20 64 -205.125 -20 65.875 -205.125
3 16 -6.1232 49.2176 -205.125 -6.1232 65.875 -205.125 -11.3136 52.6864 -205.125
3 16 -11.3136 52.6864 -205.125 -6.1232 65.875 -205.125 -14.7824 57.8768 -205.125
3 16 -14.7824 57.8768 -205.125 -6.1232 65.875 -205.125 -16 64 -205.125
3 16 -16 64 -205.125 -6.1232 65.875 -205.125 -16 65.875 -205.125
3 16 -6.1232 65.875 -209.125 -6.1232 49.2176 -209.125 -11.3136 52.6864 -209.125
3 16 -6.1232 65.875 -209.125 -11.3136 52.6864 -209.125 -14.7824 57.8768 -209.125
3 16 -6.1232 65.875 -209.125 -14.7824 57.8768 -209.125 -16 64 -209.125
3 16 -6.1232 65.875 -209.125 -16 64 -209.125 -16 65.875 -209.125
3 16 -29.8768 49.2176 -209.125 -29.8768 65.875 -209.125 -24.6864 52.6864 -209.125
3 16 -24.6864 52.6864 -209.125 -29.8768 65.875 -209.125 -21.2176 57.8768 -209.125
3 16 -21.2176 57.8768 -209.125 -29.8768 65.875 -209.125 -20 64 -209.125
3 16 -20 64 -209.125 -29.8768 65.875 -209.125 -20 65.875 -209.125
4 16 -6.1232 49.2176 -209.125 -6.1232 65.875 -209.125 -6.1232 65.875 -205.125 -6.1232 49.2176 -205.125
4 16 -29.8768 65.875 -205.125 -29.8768 65.875 -209.125 -29.8768 49.2176 -209.125 -29.8768 49.2176 -205.125
4 16 -20 65.875 -209.125 -16 65.875 -209.125 -16 64 -209.125 -20 64 -209.125
1 16 -18 64 -210.5625 2 0 0 0 -1 0 0 0 1.4375 rect.dat
2 24 -29.8768 49.2176 -209.125 -29.8768 65.875 -209.125
2 24 -29.8768 49.2176 -205.125 -29.8768 65.875 -205.125
2 24 -6.1232 49.2176 -209.125 -6.1232 65.875 -209.125
2 24 -6.1232 49.2176 -205.125 -6.1232 65.875 -205.125
2 24 -20 88 -205.125 -16 88 -205.125
1 16 36 64 -205.125 16 0 0 0 0 -16 0 4 0 5-16cyli.dat
1 16 36 64 -205.125 16 0 0 0 0 -16 0 1 0 5-16edge.dat
1 16 36 64 -205.125 -16 0 0 0 0 -16 0 4 0 1-8cyli.dat
1 16 36 64 -205.125 -16 0 0 0 0 -16 0 1 0 1-8edge.dat
4 16 25.8768 51.89084 -205.125 24.6864 52.6864 -205.125 24.6864 52.6864 -201.125 25.8768 51.89084 -201.125
2 24 25.8768 51.89084 -205.125 24.6864 52.6864 -205.125
1 16 -36 64 -205.125 16 0 0 0 0 -16 0 4 0 1-8cyli.dat
1 16 -36 64 -205.125 -16 0 0 0 0 -16 0 4 0 5-16cyli.dat
3 16 -24.6864 52.6864 -205.125 -29.8768 49.2176 -205.125 -24.6864 52.6864 -201.125
3 16 -24.6864 52.6864 -201.125 -29.8768 49.2176 -205.125 -25.8768 51.89084 -201.125
3 16 -25.8768 51.89084 -201.125 -29.8768 49.2176 -205.125 -29.8768 49.2176 -201.125
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]1 16 -36 64 -205.125 -16 0 0 0 0 -16 0 1 0 2-4edge.dat[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]------------------------------------------------------------------[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 ~Electric Technic Motor 4.5V 6 x 17 x 5 Base Type 2[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]0 Name: 32289b.dat[/size][/font][/size][/color]
1 16 0 0 0 1 0 0 0 1 0 0 0 1 32289bs01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 32289bs02.dat
1 16 0 0 0 -1 0 0 0 1 0 0 0 1 32289bs01.dat
0
[color=#333333][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]1 16 -36 64 -205.125 -16 0 0 0 0 -16 0 1 0 2-4edge.dat[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/color][/font][/size][/color]
[color=#333333][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif][color=#333333][size=small][size=small][size=small][font=Tahoma, Verdana, Arial, sans-serif]------------------------------------------------------------------[/size][/size][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/size][/size][/color][/font][/size][/font][/size][/color][/color]
