Full Version: Part 32289b modifications and new parts
Pages: 1 2
(2021-03-05, 14:41)Willy Tschager Wrote: [ -> ]Javier,
looks good to me, presuming you add the missing edges such as these:
2 4 -22 74 32 -22 96 32
2 4 -17.48 74.78 60 -17.74 76 60
2 4 0 48 -205.125 -6.1232 49.2176 -205.125
2 4 6.1232 49.2176 -205.125 0 48 -205.125
or eliminating these:
2 24 0 44 -78.875 0 48 -78.875
2 24 -36 44 -78.875 -36 48 -78.875
* Also the whole naming with the missing s\ has to be fixed.
* I cannot see any reason for not inlining s\32289as02.dat or s\32289bs02.dat (which BTW is almost coming through the surface) into the main part a and b.
* It is clear to me that you're a very talented part author for the simple fact that you have the courage to tackle such a monster but I still don't get your tendency for T-Junctions such as this:
4 4 -34 92 31 -34 92 28 -22 92 28 -22 92 31
4 4 -36 92 28 -34 92 28 -34 92 30 -36 92 30
4 4 -36 92 28 -36 92 13 0 92 13 0 92 28
4 4 -16 92 13 -16 92 8 0 92 8 0 92 13
4 4 -16 92 8 -16 92 -13 0 92 -13 0 92 8
4 4 -40 92 8 -40 92 -13 -32 92 -13 -32 92 8
4 4 -36 92 13 -36 92 8 -32 92 8 -32 92 13
which I would build with this code:
4 1 -32 92 13 -34 92 30 -36 92 30 -36 92 13
4 1 -22 92 28 -34 92 30 -32 92 13 -16 92 13
4 1 -22 92 28 -16 92 13 0 92 13 0 92 28
4 1 -36 92 8 -40 92 8 -40 92 -13 -32 92 -13
4 1 -34 92 30 -22 92 28 -22 92 31 -34 92 31
4 1 -16 92 13 -16 92 -13 0 92 -13 0 92 13
4 1 -36 92 13 -36 92 8 -32 92 -13 -32 92 13
Just out of curiosity. What tools are you using for authoring?
  1. About the inlining: Are you suggesting to add the missing edges to the primary subfile 32289s01?
  2. "The whole naming with the missing s\": it's the 32289s01 or another file?
  3. Thank you for your words but I don't think I'm talented; I just trying to correct something bad. The t-junction problem: if it is the s\32289as01, honestly, it's a copy and paste from the already submitted s/32289as01, with the corresponding deletions and minor adjustments.
Almost forgot: I use LDPE
(2021-03-05, 18:21)Javier Orquera Wrote: [ -> ]
1. The edges go, where they belong. These:
2 3 -56 60 -165 -56 60 -145
2 3 -56 60 -145 -56 60 -125
2 3 -56 60 -125 -56 60 -105
2 3 -56 60 -105 -56 60 -90
2 3 -56 60 -90 -56 60 -75
2 3 -56 60 -75 -56 60 -68
2 3 -6.1232 49.2176 -205.125 0 48 -205.125
go to 32289s01.dat
This:
2 2 -17.48 74.78 60 -17.74 76 60
goes to s\32289as01.dat (BTW there is an empty comment "0" right at the start of the edges section which has to be deleted).
2. https://www.ldraw.org/part-number-spec.html#subparts
The subparts are missing a "s\" in the part name "0 Name: s\32289s01.dat", the parts itself miss the s\ in the reference:
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\32289s01.dat
3. As you use LDPE did you try resolving your T-Junk with "Actions... > Merge To Last Selected Vertex (STRG+E)"? Do you run "Tools... > Edger2" to find your missing edges an conds?
Here it is the files with the changes.
(2021-03-08, 2:32)Javier Orquera Wrote: [ -> ]Here it is the files with the changes.
Overall structure looks good to me. Submit to the PT. This is not the place to review. Just one thing:
32289as01.dat
* Misses a lot of edges:
2 4 -20 74 54 -20 74 48
2 4 -20 74 48 -22 74 48
2 4 -20 74 54 -20 78 54
2 4 -20 78 54 -20 78 56
or conds
5 9 -17.48 74.78 60 -17.48 74.78 56 -17.74 76 60 -13.3 68.7 60
* Things like these:
4 9 -22 96 30 -22 96 32 -20 96 32 -20 96 30
4 9 -20 96 32 -20 74 32 -20 74 30 -20 96 30
4 9 -20 96 32 -22 96 32 -22 74 32 -20 74 32
4 2 -20 78 54 -15 78 54 -15 74 54 -20 74 54
4 2 -20 78 56 -15 78 56 -15 78 54 -20 78 54
4 2 -15 78 56 -15 74 56 -15 74 54 -15 78 54
could be boxed. https://www.ldraw.org/library/primref/#rect3d
* You should run it through "Rectifier" prior submission
32289bs01.dat
* There's a gap:
2 4 -40 45.4443 31.69 -40 45.4443 31.6849
* The cutout 1 16 0 92 37.7 0 0 -6.55 4 0 0 0 1 0 1-4disc.dat is a thick as the bottom itself. The thickness of the remaining structure would be zero.
* Excellent work on all the T-Junk but there is still room for improvement:
2 31 -22 92 37.7 -11.5 92 37.7
2 31 -11.5 92 22 -4.63 92 22
2 31 -26 96 60 -22 96 60
Proposed new structure of these motors.
I'm not sure of the red partnumbers. Since the uncoloured part is 32288, maybe the assembly should use that number as base.
[attachment=6697]
Magnus Forsberg Wrote:Proposed new structure of these motors.
I'm somewhat sceptic to this scheme as:
* 32288c01.dat - Electric Technic Motor 4.5V  6 x 17 x  5 with Dark Grey Base Type 1
is used only in one set and exclusively in Dark Grey
https://lego.brickinstructions.com/08000/8472/081.jpg
* 32288c02.dat - Electric Technic Motor 4.5V  6 x 17 x  5 with Light Grey Base Type 2
is used only in three sets and exclusively in Light Grey
https://lego.brickinstructions.com/05000/5221/003.jpg
https://lego.brickinstructions.com/08000/8279/010.jpg
https://lego.brickinstructions.com/08000/8307/004.jpg
Ok,
Then maybe skip the middle assembly.
I want to see the top level contaning: only the movable and removable parts + a complete assemby of the non-moving body parts.
Think animation. As a user, I want to inline the top level shortcut, and then flick the switch or rotate an axle.
Pages: 1 2
