2020-05-06, 17:28
2020-05-06, 17:31
2020-05-07, 6:13
(2020-05-06, 17:31)Orion Pobursky Wrote: [ -> ]75277 - Boba FettNice!
OMR Compliant
Missing: Printed label plate
If you did not notice yet I uploaded the patterned part yesterday on PT: https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/6180ps1.dat
It was not reviewed yet so it may contain issues.
2020-05-07, 14:23
(2020-05-07, 6:13)Vincent Messenet Wrote: [ -> ]Nice!
Oh, awesome. I tried to order this set for May 4th but it was sold out with no backorder option :/
2020-05-07, 19:07
(2020-05-06, 17:28)Orion Pobursky Wrote: [ -> ]Thread for Star Wars 2020 ModelsAlready posted in the thread "Star Wars Mini Series"
40407 - Death Star II Battle
[attachment=5193]
2020-05-07, 19:20
Looks great.
I think theme by year (for large themes) is the way to go unless there's an obvious subset (Modulars, UCS Models, etc...)
2020-05-08, 3:21
(2020-05-07, 14:23)Orion Pobursky Wrote: [ -> ]Oh, awesome. I tried to order this set for May 4th but it was sold out with no backorder option :/
Yes, it was super aggravating that they used these three helmet sets in their early ad copy for May the 4th, and then sold out of two of them, and only allowed backorders for the tie fighter pilot.
2020-05-25, 11:54
Just to let you know I am doing the TIE-Fighter pilot and Stormtrooper helmets.
TIE pilot done, exept the airtubes. Any idea how to model those?
Stormtrooper almost done.
Will post draft files soon and make OMR.
2020-05-26, 7:12
75276 - Stormtrooper
[attachment=5301]
OMR compliant? MPDCenter says not, but I cannot resolve the problems it reports.
Can someone take a look?
Missing stickers
[attachment=5301]
Missing stickers
2020-05-26, 7:13
75274 - TIE Fighter pilot
[attachment=5303]
Not OMR compliant yet.
Missing air tubes. Any ideas on how to model those?
Missing stickers.
Pattern on 4x4 dishes done with texture mapping.
[attachment=5303]
Missing stickers.
2020-05-26, 15:50
(2020-05-26, 7:13)Jaco van der Molen Wrote: [ -> ]Missing air tubes. Any ideas on how to model those?
Looks like that's made with these train wheels:
https://www.ldraw.org/parts/official-par...rtid=50254
You could devise an LDCad template using these as donor parts, I should think.
2020-05-26, 16:11
(2020-05-26, 15:50)N. W. Perry Wrote: [ -> ]Looks like that's made with these train wheels:
Yah, definitely could do this with LDCad flex objects. I'll see what I can gen up if someone else doesn't beat me to it.
2020-05-26, 17:19
(2020-05-26, 7:12)Jaco van der Molen Wrote: [ -> ]OMR compliant? MPDCenter says not, but I cannot resolve the problems it reports.
First thing needed to do was add the "LDRAW_ORG Model" line to all subfiles. After changing the main file with the header dialog, MPDCenter offered to automatically change the rest as well.
Next, some file titles (description) don't match the Name line (they list multiple step numbers, for example). This was most easily fixed in LDCad with Clean Up…sync name and sync description.
One file had an incorrect header sequence, and another had an unofficial part needing to be added. (LDCad's Clean Up could have handled this as well, but I did them separately.)
After adding the unofficial part, it and its subfiles just needed to be renamed for OMR conformity. Again, LDCad's Clean Up works (first remove set number prefixes, then re-add them to everything, otherwise you'll get double prefixes for those files that were already correct).
The resulting file passes OMR check and is attached (after fixing the filename to .mpd and deleting duplicate licenses in two subfiles—both of which were caught by LDInspector but not by MPDCenter):
[attachment=5310]
2020-05-27, 17:24
(2020-05-26, 17:19)N. W. Perry Wrote: [ -> ]First thing needed to do was add the "LDRAW_ORG Model" line to all subfiles. After changing the main file with the header dialog, MPDCenter offered to automatically change the rest as well.
OK, tnx Perry!
Where can I find Clean Up… sync name and sync description in LDCad?
2020-05-27, 18:18
(2020-05-27, 17:24)Jaco van der Molen Wrote: [ -> ]OK, tnx Perry!
Clean Up is in the File menu.
2020-05-27, 19:26
(2020-05-27, 18:18)Orion Pobursky Wrote: [ -> ]Clean Up is in the File menu.
Oh dear, never knew about its existence
2020-07-22, 6:28
2020-11-15, 16:52
