2020-05-06, 10:57
2020-05-06, 13:09
(2020-05-06, 10:57)ragnarok Wrote: [ -> ]I drew some Lego parts with 3dmx. How can I import them into LDraw or studio 2.0?The most reliable method is to export them to .stl file format (ASCII) then convert them to LDraw parts with Stl2Dat (http://marc.klein.free.fr/lego/stl2dat/s...ml#version) or with LETGUI that also contains a copy of stl2dat (https://ldraw.heidemann.org/index.php?page=letgui)
Take care of units (1 unit = 0.4mm), scale if needed...
2020-05-07, 8:13
(2020-05-06, 13:09)Philippe Hurbain Wrote: [ -> ]The most reliable method is to export them to .stl file format (ASCII) then convert them to LDraw parts with Stl2Dat (http://marc.klein.free.fr/lego/stl2dat/s...ml#version) or with LETGUI that also contains a copy of stl2dat (https://ldraw.heidemann.org/index.php?page=letgui)
Thank you for your reply. I have started drawing today. Is there anything I need to pay attention to in the drawing process?
2020-05-07, 10:33
(2020-05-07, 8:13)ragnarok Wrote: [ -> ]
Take the recommendation:
http://marc.klein.free.fr/lego/parts/modelise.html
by heart. Model in LDU and not mm and fake a mathematical circle by polygons. Therefore
https://www.ldraw.org/library/primref/
2020-05-07, 11:09
Yes, I don't think we can emphasis that enough.
You should always have the primitives in mind. Don't think that you can do complete, finished parts in another software.
That mesh is to be seen as raw data that still need a lot of adopting. You should use as many primitives as possible in the finished part.
If I where to use another software, I would begin to investigate if it is possible to have a library of "primitives", to use in that software.
We build parts like you normally build a lego set, but we use primitives instead of bricks.
2020-05-07, 16:56
(2020-05-07, 10:33)Willy Tschager Wrote: [ -> ]Take the recommendation:Thank you again for your reply. I have made a model today and successfully converted it to “dat” format. How can I use it in “studio2.0” or “LeoCAD” next? I tried several methods today, but none of them will work.
by heart. Model in LDU and not mm and fake a mathematical circle by polygons. Thereforeis 16 polygons. Model with primitive substitution in mind:
2020-05-07, 16:58
Thank you for your suggestion. I used leocad to export some obj formats and import 3DMAX as the basis of my work.
2020-05-07, 17:13
(2020-05-07, 16:56)ragnarok Wrote: [ -> ]Thank you again for your reply. I have made a model today and successfully converted it to “dat” format. How can I use it in “studio2.0” or “LeoCAD” next? I tried several methods today, but none of them will work.
To use it in Studio, make sure it's saved in your Custom Parts directory, then you can drag it into your project like any part. You can also import it into Part Designer and export it to Studio format from there.
However, the .dat file type is not appropriate for model files—those should be saved as .ldr (or .mpd if they contain submodels).
2020-05-11, 3:35
(2020-05-07, 11:09)Magnus Forsberg Wrote: [ -> ]Yes, I don't think we can emphasis that enough.
Thank you. I see.
I make "DUPLO" parts. Where should I look for the original model or data?
For example, the length, width and height of "DUPLO" 2 * 4 brick, whether there is standard data
2020-05-11, 13:26
(2020-05-11, 3:35)ragnarok Wrote: [ -> ]Thank you. I see.
This is an article I wrote a long time ago and should hopefully get you some clues:
http://www.holly-wood.it/ldraw/authoring-en.html
Note that beside professional tools we use LPDE to get our parts ready:
