Full Version: How to get 45002 parts
Hello everyone, because the children at home like 45002 building blocks very much, so I want to use 45002 parts to design works, but I can't find 45002 parts in the library, where can I download them? Thank you Big Grin
The set has 27 unique parts, but unfortunately a quick search showed me that there are only two in the Library, 2x2 Brick (3437) and the 8x8 Plate (51262)
A quick search in the basement turned up 13 more:
[color=#0563c1]6294[/color]                 [color=black]Orange Duplo, Toolo Scoop 6 x 4 x 3[/color]
[color=#0563c1]6345[/color]                 [color=black]Trans-Yellow Duplo Windscreen 4 x 4 x 2 Curved[/color]
[color=#0563c1]10566[/color]               [color=black]Light Bluish Gray Duplo Utensil Shovel / Spade with D Handle and Short Blade (total length 75mm)[/color]
[color=#0563c1]13355[/color]               [color=black]Black Duplo, Plate 2 x 3 with 4 Studs and Hinge[/color]
[color=#0563c1]16310[/color]               [color=black]Orange Duplo, Toolo Digger Bucket with 3 Teeth[/color]
[color=#0563c1]14013c01[/color]        [color=black]Light Bluish Gray Duplo Winch Drum Narrow Ridged with String and Black Hook[/color]
[color=#0563c1]31184c01[/color]        [color=black]Dark Bluish Gray Duplo, Toolo Brick 2 x 4 with Holes on Sides and Top and 1 Screw in Top[/color]
[color=#0563c1]31350c01[/color]        [color=black]Light Bluish Gray Duplo, Toolo Wheel with Action Wheeler Screw[/color]
[color=#0563c1]6275c01[/color]          [color=black]Dark Bluish Gray Duplo, Toolo Arm 2 x 6 with Triangular Set Screw and Clip Ends[/color]
[color=#0563c1]6297c01[/color]          [color=black]Black Duplo, Toolo Turntable 4 x 4 Base with Yellow Top Plate [/color]
[color=#0563c1]dt001c01[/color]         [color=black]Red Duplo, Toolo Tool Handle with Light Gray Screwdriver Shank[/color]
[color=#0563c1]x1228[/color]               [color=black]Black Duplo Tread, Thick Cleats[/color]
[color=black]31352              Toolo Digger Bucket with 3 Teeth[/color]
[color=black]although I have them, they are not really at the top of my to-do list. So I can't promise anything....[/color]
Thank you for your reply. I hope these parts can be finished earlier. Which software should I use if I want to draw by myself?
