2020-02-08, 14:51
I'm looking to clarify the use of optional qualifiers in the OMR spec.
Under Base File Naming, the requirements for the optional qualifier are:
6901 - Mobile Lab.mpd (Produced in 1980)
6901-1 - Submodel1.ldr
6901-1 - Submodel2.ldr
6901-1 - part.dat
6901-2 - Space Plane.mpd (Produced in 1998)
Likewise, the example given for an embedded unofficial part is:
33956.dat would be renamed to 3345 - 33956.dat or 3345-1 - 33956.dat[color=rgba(0, 0, 0, 0.87)].[/color]
In either case, the underlying base filename would be 3345 - Set Name.mpd (because "-1" is not a valid optional qualifier for the base filename, or because there is only one set numbered 3345).
Is this the intended interpretation of the spec? Or is it intended that <Set Number>[-<Optional Qualifier>] be identical for the base filename and all subfile names (and if so, should the optional qualifier start at 1 or 2)?
- "[i]s a sequential number, starting with 2."
- "…is not mandatory and gets added only if there is more than one set that could be assigned the same <Set Number>. The first set using a given number would be understood to never contain the qualifier however numbering should start with the oldest set and some investigation should be done in existing set databases."
- "is a sequential number, starting with 1, added if there is more than one set that could be assigned <Set Number>."
6901-1 - part.dat
