Full Version: AIOI 2019-03 Release candidate ready for testing
Pages: 1 2
The release candidate of the AIOI 2019-03 can be downloaded here:
http://www.holly-wood.it/tmp/LDraw_AIOI_...bit_v1.exe
Change log:
* Update to Parts Library 2019-03
* Update to MLCad.ini 2019-03
* Update to LPub3D 2.3.133.1624
* Update to LeoCAD 19.07
* Update to Offline Parts Catalog 2019-03
Your testing would be appreciated.
Can I opt out of installing LDView? I have a development version installed now and don't want to overwrite it. Normally the AIOI forces you to install LDView.
(2020-02-02, 19:43)Michael Horvath Wrote: [ -> ]Can I opt out of installing LDView? I have a development version installed now and don't want to overwrite it. Normally the AIOI forces you to install LDView.
No, the filetypes are registered to LDView and a lot of other things.
(2020-02-02, 19:59)Willy Tschager Wrote: [ -> ]No, the filetypes are registered to LDView and a lot of other things.
And really the AIOI is intended to get you started. Once you use it, you should be upgrading the individual components.
(2020-02-03, 2:13)Orion Pobursky Wrote: [ -> ]And really the AIOI is intended to get you started. Once you use it, you should be upgrading the individual components.
Will the AIOI uninstaller still work properly after I upgrade each component? I don't want leftover files or registry entries if something gets borked.
(2020-02-04, 7:28)Michael Horvath Wrote: [ -> ]Will the AIOI uninstaller still work properly after I upgrade each component? I don't want leftover files or registry entries if something gets borked.
This is the Pre Uninstaller Script:
if (System.Is64BitOS()) then
    -- Checks to see if LDViewThumbs.dll and LDViewThumbs64.dll exists.
    sLDViewThumbsPath = SessionVar.Expand ("%AppFolder%\\LDraw\\LDView\\LDViewThumbs.dll");
    sLDViewThumbs64Path = SessionVar.Expand("%AppFolder%\\LDraw\\LDView\\LDViewThumbs64.dll");
    local sToggle = "/u /s ";
    local sArguments = String.Concat(sToggle, '"' .. sLDViewThumbsPath .. '"');
    local sArguments64 = String.Concat(sToggle, '"' .. sLDViewThumbs64Path .. '"');
    bLDViewThumbsExists = File.DoesExist(sLDViewThumbsPath);
    bLDViewThumbs64Exists = File.DoesExist(sLDViewThumbs64Path);
        -- If LDViewThumbs.dll does exist, unregister it
        if bLDViewThumbsExists then
            Shell.Execute(_WindowsFolder .. "\\SysWOW64\\regsvr32.exe", "open", sArguments, "", SW_SHOWNORMAL, true);
            SetupData.WriteToLogFile("Unregistered LDViewThumbs.dll", true);
            -- If an error occurred, display the error message.
            error = Application.GetLastError();
            if (error ~= 0) then
                Dialog.Message("Error", _tblErrorMessages[error], MB_OK, MB_ICONEXCLAMATION);
                local sMessage = "####################\r\n" .. "ERROR " .. error .. ": " .. _tblErrorMessages[error] .. "\r\n####################\r\n";
                SetupData.WriteToLogFile(sMessage, false);
            end
        end
        -- If the file does exist, unregister it
        if bLDViewThumbs64Exists then
            Shell.Execute(_SystemFolder .."\\regsvr32.exe", "open", sArguments64, "", SW_SHOWNORMAL, true);
            SetupData.WriteToLogFile("Unregistered LDViewThumbs64.dll", true);
            end
        end
    else
    -- The user's system is running a 32 bit operating system.
        -- If LDViewThumbs.dll does exist, un register it
            Shell.Execute(_SystemFolder .. "\\regsvr32.exe", "open", sArguments, "", SW_SHOWNORMAL, false);
            end
        end
end
This is the Post Uninstaller Script
-- Delete shortcuts in LDraw shortcut folder
sShortcutFolderPath = SetupData.GetAppShortcutFolderPath();
Folder.DeleteTree(sShortcutFolderPath, nil);
-- Check to see if any error occurred.
local error = Application.GetLastError();
    else
        SetupData.WriteToLogFile("Deleted LDraw shortcuts tree\r\n", false);
    end
-- Delete the registry value for the LDRAWDIR system variable
    Registry.DeleteValue(HKEY_LOCAL_MACHINE, "SYSTEM\\CurrentControlSet\\Control\\Session Manager\\Environment", "LDRAWDIR");
    else
        SetupData.WriteToLogFile("Delete the registry value for the LDRAWDIR system variable\r\n", false);
    end
-- Delete all registry keys for MLCad if MLCad keys exist
sMLCadRegistryExists = Registry.DoesKeyExist(HKEY_CURRENT_USER, "Software\\Lachmann");
if (sMLCadRegistryExists == true) then
    Registry.DeleteKey(HKEY_CURRENT_USER, "Software\\Lachmann");
    else
        SetupData.WriteToLogFile("Deleted all registry keys for MLCad if MLCad keys existed\r\n", false);
    end
end
-- Delete all registry keys for LeoCAD if LeoCAD keys exist
sLeoCADRegistryExists = Registry.DoesKeyExist(HKEY_CURRENT_USER, "Software\\LeoCAD Software");
if (sLeoCADRegistryExists == true) then
    Registry.DeleteKey(HKEY_CURRENT_USER, "Software\\LeoCAD Software");
    else
        SetupData.WriteToLogFile("Deleted all registry keys for LeoCAD if LeoCAD keys existed\r\n", false);
    end
end
-- Delete all registry keys for LDView if LDView keys exist
sLDViewRegistryExists = Registry.DoesKeyExist(HKEY_CURRENT_USER, "Software\\Travis Cobbs");
if (sLDViewRegistryExists == true) then
    Registry.DeleteKey(HKEY_CURRENT_USER, "Software\\Travis Cobbs");
    Registry.DeleteKey(HKEY_LOCAL_MACHINE, "SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\App Paths\\LDView.exe");
    Registry.DeleteKey(HKEY_CLASSES_ROOT, "Applications\\LDView.exe");
    Registry.DeleteKey(HKEY_CLASSES_ROOT, ".ldr");
    Registry.DeleteKey(HKEY_CLASSES_ROOT, "LDView.ldr");
    Registry.DeleteKey(HKEY_CLASSES_ROOT, ".mpd");
    Registry.DeleteKey(HKEY_CLASSES_ROOT, "LDView.mpd");
    else
        SetupData.WriteToLogFile("Deleted all registry keys for LDView if LDView keys existed\r\n", false);
    end
end
-- Delete all registry keys for LPub3D if LPub3D keys exist
sLPub3DRegistryExists = Registry.DoesKeyExist(HKEY_CURRENT_USER, "Software\\LPub3D Software");
if (sLPub3DRegistryExists == true) then
    Registry.DeleteKey(HKEY_CURRENT_USER, "Software\\LPub3D Software");
    else
        SetupData.WriteToLogFile("Deleted all registry keys for LPub3D if LPub3D keys existed\r\n", false);
    end
end
This is the Shutdown script
-- Delete LDraw folder if still present
sRootFolderExists = Folder.DoesExist(SessionVar.Expand("%AppFolder%"));
if (sRootFolderExists == true) then
    -- Delete entire root tree
    Folder.DeleteTree(SessionVar.Expand("%AppFolder%"), nil);
    else
        SetupData.WriteToLogFile("Deleted LDraw root folder if still present\r\n", false);
    end
end
-- Delete LDraw Parts library if still present
sLibraryFolderExists = Folder.DoesExist(SessionVar.Expand("%CommonDocumentsFolder%\\LDraw"));
if (sLibraryFolderExists == true) then
    Folder.DeleteTree(SessionVar.Expand("%CommonDocumentsFolder%\\LDraw"), nil);
    else
        SetupData.WriteToLogFile("Deleted LDraw Parts library if still present\r\n", false);
    end
end
-- Delete LDraw folder in Virtualstore if still present
sVirtualstoreFolderExists = Folder.DoesExist(SessionVar.Expand("%AppDataLocal%" .. "\\VirtualStore\\Program Files (x86)\\LDraw"));
if (sVirtualstoreFolderExists == true) then
    -- Delete entire LDraw tree
    Folder.DeleteTree(SessionVar.Expand("%AppDataLocal%" .. "\\VirtualStore\\Program Files (x86)\\LDraw"), nil);
        else
            SetupData.WriteToLogFile("Deleted LDraw folder in Virtualstore if still present\r\n", false);
        end
end
-- Delete LDCad folder in AppData if still present
sLDCadFolderExists = Folder.DoesExist(SessionVar.Expand("%ApplicationDataFolder%" .. "\\LDCad"));
if (sLDCadFolderExists == true) then
    -- Delete entire LDCad tree
    Folder.DeleteTree(SessionVar.Expand("%ApplicationDataFolder%" .. "\\LDCad"), nil);
        else
            SetupData.WriteToLogFile("Deleted LDCad folder in AppData if still present\r\n", false);
        end
end
-- Delete MLCad folder in AppData if still present
sMLCadFolderExists = Folder.DoesExist(SessionVar.Expand("%ApplicationDataFolder%" .. "\\Ing. Michael Lachmann"));
if (sMLCadFolderExists == true) then
    -- Delete entire MLCad tree
    Folder.DeleteTree(SessionVar.Expand("%ApplicationDataFolder%" .. "\\Ing. Michael Lachmann"), nil);
        else
            SetupData.WriteToLogFile("Deleted MLCad folder in AppData if still present\r\n", false);
        end
end
-- Delete LPub3D folder in AppData if still present
sLPub3DFolderExists = Folder.DoesExist(SessionVar.Expand("%AppDataLocal%" .. "\\LPub3D Software"));
if (sLPub3DFolderExists == true) then
    -- Delete entire LPub3D tree
    Folder.DeleteTree(SessionVar.Expand("%AppDataLocal%" .. "\\LPub3D Software"), nil);
        else
            SetupData.WriteToLogFile("Deleted LPub3D folder in AppData if still present\r\n", false);
        end
end
-- Delete LICreator folder in AppData if still present
sLICreatorFolderExists = Folder.DoesExist(SessionVar.Expand("%ApplicationDataFolder%" .. "\\licreator"));
if (sLICreatorFolderExists == true) then
    -- Delete entire LICreator tree
    Folder.DeleteTree(SessionVar.Expand("%ApplicationDataFolder%" .. "\\licreator"), nil);
        else
            SetupData.WriteToLogFile("Deleted LICreator folder in AppData if still present\r\n", false);
        end
end
Hope this helps.
Thanks, I will take a look.
I haven't tested this release candidate, but unless I did something wrong the previous version only added the Start Menu and Desktop icons for the admin user. Could we have an option to do this for "all users"? Or does it already have this option and I simply missed it? Thanks.
MPDCenter should also be updated.
Update 01.01.2019
Version: 2.5.1.0
(2020-02-10, 22:51)Michael Horvath Wrote: [ -> ]I haven't tested this release candidate, but unless I did something wrong the previous version only added the Start Menu and Desktop icons for the admin user. Could we have an option to do this for "all users"? Or does it already have this option and I simply missed it? Thanks.
I'll have to look into it.
Pages: 1 2
