(2020-02-04, 7:28)Michael Horvath Wrote: [ -> ]Will the AIOI uninstaller still work properly after I upgrade each component? I don't want leftover files or registry entries if something gets borked.
This is the Pre Uninstaller Script:
if (System.Is64BitOS()) then
-- Checks to see if LDViewThumbs.dll and LDViewThumbs64.dll exists.
sLDViewThumbsPath = SessionVar.Expand ("%AppFolder%\\LDraw\\LDView\\LDViewThumbs.dll");
sLDViewThumbs64Path = SessionVar.Expand("%AppFolder%\\LDraw\\LDView\\LDViewThumbs64.dll");
local sToggle = "/u /s ";
local sArguments = String.Concat(sToggle, '"' .. sLDViewThumbsPath .. '"');
local sArguments64 = String.Concat(sToggle, '"' .. sLDViewThumbs64Path .. '"');
bLDViewThumbsExists = File.DoesExist(sLDViewThumbsPath);
bLDViewThumbs64Exists = File.DoesExist(sLDViewThumbs64Path);
-- If LDViewThumbs.dll does exist, unregister it
if bLDViewThumbsExists then
Shell.Execute(_WindowsFolder .. "\\SysWOW64\\regsvr32.exe", "open", sArguments, "", SW_SHOWNORMAL, true);
SetupData.WriteToLogFile("Unregistered LDViewThumbs.dll", true);
-- If an error occurred, display the error message.
error = Application.GetLastError();
if (error ~= 0) then
Dialog.Message("Error", _tblErrorMessages[error], MB_OK, MB_ICONEXCLAMATION);
local sMessage = "####################\r\n" .. "ERROR " .. error .. ": " .. _tblErrorMessages[error] .. "\r\n####################\r\n";
SetupData.WriteToLogFile(sMessage, false);
end
end
-- If the file does exist, unregister it
if bLDViewThumbs64Exists then
Shell.Execute(_SystemFolder .."\\regsvr32.exe", "open", sArguments64, "", SW_SHOWNORMAL, true);
SetupData.WriteToLogFile("Unregistered LDViewThumbs64.dll", true);
end
end
else
-- The user's system is running a 32 bit operating system.
-- If LDViewThumbs.dll does exist, un register it
Shell.Execute(_SystemFolder .. "\\regsvr32.exe", "open", sArguments, "", SW_SHOWNORMAL, false);
end
end
end
This is the Post Uninstaller Script
-- Delete shortcuts in LDraw shortcut folder
sShortcutFolderPath = SetupData.GetAppShortcutFolderPath();
Folder.DeleteTree(sShortcutFolderPath, nil);
-- Check to see if any error occurred.
local error = Application.GetLastError();
else
SetupData.WriteToLogFile("Deleted LDraw shortcuts tree\r\n", false);
end
-- Delete the registry value for the LDRAWDIR system variable
Registry.DeleteValue(HKEY_LOCAL_MACHINE, "SYSTEM\\CurrentControlSet\\Control\\Session Manager\\Environment", "LDRAWDIR");
else
SetupData.WriteToLogFile("Delete the registry value for the LDRAWDIR system variable\r\n", false);
end
-- Delete all registry keys for MLCad if MLCad keys exist
sMLCadRegistryExists = Registry.DoesKeyExist(HKEY_CURRENT_USER, "Software\\Lachmann");
if (sMLCadRegistryExists == true) then
Registry.DeleteKey(HKEY_CURRENT_USER, "Software\\Lachmann");
else
SetupData.WriteToLogFile("Deleted all registry keys for MLCad if MLCad keys existed\r\n", false);
end
end
-- Delete all registry keys for LeoCAD if LeoCAD keys exist
sLeoCADRegistryExists = Registry.DoesKeyExist(HKEY_CURRENT_USER, "Software\\LeoCAD Software");
if (sLeoCADRegistryExists == true) then
Registry.DeleteKey(HKEY_CURRENT_USER, "Software\\LeoCAD Software");
else
SetupData.WriteToLogFile("Deleted all registry keys for LeoCAD if LeoCAD keys existed\r\n", false);
end
end
-- Delete all registry keys for LDView if LDView keys exist
sLDViewRegistryExists = Registry.DoesKeyExist(HKEY_CURRENT_USER, "Software\\Travis Cobbs");
if (sLDViewRegistryExists == true) then
Registry.DeleteKey(HKEY_CURRENT_USER, "Software\\Travis Cobbs");
Registry.DeleteKey(HKEY_LOCAL_MACHINE, "SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\App Paths\\LDView.exe");
Registry.DeleteKey(HKEY_CLASSES_ROOT, "Applications\\LDView.exe");
Registry.DeleteKey(HKEY_CLASSES_ROOT, ".ldr");
Registry.DeleteKey(HKEY_CLASSES_ROOT, "LDView.ldr");
Registry.DeleteKey(HKEY_CLASSES_ROOT, ".mpd");
Registry.DeleteKey(HKEY_CLASSES_ROOT, "LDView.mpd");
else
SetupData.WriteToLogFile("Deleted all registry keys for LDView if LDView keys existed\r\n", false);
end
end
-- Delete all registry keys for LPub3D if LPub3D keys exist
sLPub3DRegistryExists = Registry.DoesKeyExist(HKEY_CURRENT_USER, "Software\\LPub3D Software");
if (sLPub3DRegistryExists == true) then
Registry.DeleteKey(HKEY_CURRENT_USER, "Software\\LPub3D Software");
else
SetupData.WriteToLogFile("Deleted all registry keys for LPub3D if LPub3D keys existed\r\n", false);
end
end
This is the Shutdown script
-- Delete LDraw folder if still present
sRootFolderExists = Folder.DoesExist(SessionVar.Expand("%AppFolder%"));
if (sRootFolderExists == true) then
-- Delete entire root tree
Folder.DeleteTree(SessionVar.Expand("%AppFolder%"), nil);
else
SetupData.WriteToLogFile("Deleted LDraw root folder if still present\r\n", false);
end
end
-- Delete LDraw Parts library if still present
sLibraryFolderExists = Folder.DoesExist(SessionVar.Expand("%CommonDocumentsFolder%\\LDraw"));
if (sLibraryFolderExists == true) then
Folder.DeleteTree(SessionVar.Expand("%CommonDocumentsFolder%\\LDraw"), nil);
else
SetupData.WriteToLogFile("Deleted LDraw Parts library if still present\r\n", false);
end
end
-- Delete LDraw folder in Virtualstore if still present
sVirtualstoreFolderExists = Folder.DoesExist(SessionVar.Expand("%AppDataLocal%" .. "\\VirtualStore\\Program Files (x86)\\LDraw"));
if (sVirtualstoreFolderExists == true) then
-- Delete entire LDraw tree
Folder.DeleteTree(SessionVar.Expand("%AppDataLocal%" .. "\\VirtualStore\\Program Files (x86)\\LDraw"), nil);
else
SetupData.WriteToLogFile("Deleted LDraw folder in Virtualstore if still present\r\n", false);
end
end
-- Delete LDCad folder in AppData if still present
sLDCadFolderExists = Folder.DoesExist(SessionVar.Expand("%ApplicationDataFolder%" .. "\\LDCad"));
if (sLDCadFolderExists == true) then
-- Delete entire LDCad tree
Folder.DeleteTree(SessionVar.Expand("%ApplicationDataFolder%" .. "\\LDCad"), nil);
else
SetupData.WriteToLogFile("Deleted LDCad folder in AppData if still present\r\n", false);
end
end
-- Delete MLCad folder in AppData if still present
sMLCadFolderExists = Folder.DoesExist(SessionVar.Expand("%ApplicationDataFolder%" .. "\\Ing. Michael Lachmann"));
if (sMLCadFolderExists == true) then
-- Delete entire MLCad tree
Folder.DeleteTree(SessionVar.Expand("%ApplicationDataFolder%" .. "\\Ing. Michael Lachmann"), nil);
else
SetupData.WriteToLogFile("Deleted MLCad folder in AppData if still present\r\n", false);
end
end
-- Delete LPub3D folder in AppData if still present
sLPub3DFolderExists = Folder.DoesExist(SessionVar.Expand("%AppDataLocal%" .. "\\LPub3D Software"));
if (sLPub3DFolderExists == true) then
-- Delete entire LPub3D tree
Folder.DeleteTree(SessionVar.Expand("%AppDataLocal%" .. "\\LPub3D Software"), nil);
else
SetupData.WriteToLogFile("Deleted LPub3D folder in AppData if still present\r\n", false);
end
end
-- Delete LICreator folder in AppData if still present
sLICreatorFolderExists = Folder.DoesExist(SessionVar.Expand("%ApplicationDataFolder%" .. "\\licreator"));
if (sLICreatorFolderExists == true) then
-- Delete entire LICreator tree
Folder.DeleteTree(SessionVar.Expand("%ApplicationDataFolder%" .. "\\licreator"), nil);
else
SetupData.WriteToLogFile("Deleted LICreator folder in AppData if still present\r\n", false);
end
end
Hope this helps.
