Hi all,
For a MOC I have to simulate a kind of landscaping rough soil-like.
I am looking for a way in LDCad to make something like this with a script.
With it, you should be able to specify dimensions (in this case 8x8), what bricks to use (plates, tiles, etc.) and colors (like LBG, tan, white, ...)
Would that be possible?
attachment=4709]
(2020-01-22, 11:44)Jaco van der Molen Wrote: [ -> ]Hi all,
The random part is easy, the parts/colors are tricky because they need input from the user.
Below an example/starter script
genTools=require('genTools')
function onRun()
local base='41539.dat'
local baseCol=7
local yPos=-8
local colors={4,15,1,14}
local colCnt=4
local xCnt=8
local zCnt=8
local xStep=20
local zStep=20
local sf=ldc.subfile()
local ses=ldc.session()
if not ses:isLinked() then
ldc.dialog.runMessage('No session')
return
end
local sel=ses:getSelection()
local parts={}
local partCnt=sel:getRefCount()
if partCnt==0 then
ldc.dialog.runMessage('No parts in selection')
return
end
for i=1,partCnt do
parts[i]=sel:getRef(i):getName()
end
sel:remove()
local xOfs=10-xCnt*xStep/2
local zOfs=10-zCnt*zStep/2
sel:add(sf:addNewRef(base, baseCol))
for z=0,zCnt-1 do
for x=0,(xCnt-1) do
sel:add(sf:addNewRef(parts[math.random(partCnt)], colors[math.random(colCnt)], ldc.matrix(xOfs+x*xStep, yPos, zOfs+z*zStep)))
end
end
end
function register()
local macro=ldc.macro('My macro')
macro:setEvent('run', 'onRun')
end
register()
Colors are static but you could also get them from the selection if needed.
It will use the parts in the selection to randomly fill a 8x8 plate.
If you want the plate to be selected too you could do that be asking for the dimensions followed by determining the correct plate to use. Or just adjust the script constants at its top.
(2020-01-23, 18:55)Roland Melkert Wrote: [ -> ]The random part is easy, the parts/colors are tricky because they need input from the user.
function onRun()
local baseCol=7
local yPos=-8
local colCnt=4
local xCnt=8
local zCnt=8
local xStep=20
local zStep=20
return
end
local parts={}
if partCnt==0 then
return
end
for i=1,partCnt do
end
sel:remove()
for z=0,zCnt-1 do
for x=0,(xCnt-1) do
end
end
end
function register()
end
register()
OK, I'll look in to that. Looks a bit like the landscape generator "we" once made too. Thanks!
I played a little with that script and made a few modifications to address:
- Tiles, plates, bricks don't have the same Y position to sit on a plane
- Assymetric parts (eg. slopes) need orientation randomness
- Some parts are not available in all colors, so get color from each part in selection
Usage: place the seed parts on a plate at Y=0, select all seed parts, run script.
function onRun()
local baseCol=71
local xCnt=8
local zCnt=8
local xStep=20
local zStep=20
local yVect=ldc.vector(0, 1, 0)
return
end
local parts={}
local pColor={}
local yPos={}
if partCnt==0 then
return
end
for i=1,partCnt do
pColor[i]=sel:getRef(i):getColor()
yPos[i]=sel:getRef(i):getPos():getY()
end
sel:remove()
for z=0,zCnt-1 do
for x=0,(xCnt-1) do
local rnd=math.random(partCnt)
local rndYRot=ldc.matrix()
rndYRot:setRotate(math.random(4)*90,yVect)
sel:add(sf:addNewRef(parts[rnd], pColor[rnd], ldc.matrix(xOfs+x*xStep, yPos[rnd], zOfs+z*zStep)):setOri(rndYRot))
end
end
end
function register()
local macro=ldc.macro('RandomGen')
end
register()
(2020-01-24, 9:56)Philippe Hurbain Wrote: [ -> ]I played a little with that script and made a few modifications to address:- Tiles, plates, bricks don't have the same Y position to sit on a plane
function onRun()
local baseCol=71
local xCnt=8
local zCnt=8
local xStep=20
local zStep=20
return
end
local parts={}
local pColor={}
local yPos={}
if partCnt==0 then
return
end
for i=1,partCnt do
end
sel:remove()
for z=0,zCnt-1 do
for x=0,(xCnt-1) do
end
end
end
function register()
end
register()
Nice. I've had a busy weekend, but will take a look asap. Thanks Roland an Philo!
(2020-01-27, 8:48)Jaco van der Molen Wrote: [ -> ]Nice. I've had a busy weekend, but will take a look asap. Thanks Roland an Philo!
Hi Philo, Roland,
I can perfectly work with this so far.
Tnx
Jaco
