Full Version: DatHeader Error on startup
Pages: 1 2
(2020-05-14, 23:30)N. W. Perry Wrote: [ -> ]Heh, wouldn't you know…now that link is itself broken. (Bad certificate warning, followed by 503 error.) It was working mere hours ago.
Works for me. If you're using Firefox try a Ctrl-Shift-R
(2020-05-15, 0:11)Orion Pobursky Wrote: [ -> ]Works for me. If you're using Firefox try a Ctrl-Shift-R
Seems to be back up now. Chrome took a while to recover, but I was able to grab it in Safari.
I also notice I have no keywords in the official list, probably due to the same connection error?
And is the full error (body) scan always so very slow? (10-15 minutes to scan a 100 Kb file?)
(2020-05-15, 4:18)N. W. Perry Wrote: [ -> ]And is the full error (body) scan always so very slow? (10-15 minutes to scan a 100 Kb file?)
Yes. That 4MB fallback pattern I posted on a recent thread took all night to do on my machine.
(2020-01-17, 16:31)Johann Eisner Wrote: [ -> ]Hi community
When starting the latest version from DatHeader (3.0.23), I got a error message,
Missing Catecory.txt.
After confirming the dialog box, an attempt is made to download the file.
This leads to another error message.
After confirming this dialog box,...
DatHeader runs that way too, but this Zenario comes every time it starts.
Thoughts or solves?
Regards Johann
That the download does not worked might be because I had used http: instead https:. Will be fixed in the next update.
cu
Mikeheide
(2020-11-01, 16:52)Michael Heidemann Wrote: [ -> ]That the download does not worked might be because I had used http: instead https:. Will be fixed in the next update.
cu
Mikeheide
No, if I change http: to https: I do not get any connection. Changed all back to http:.
cu
Mikeheide
(2020-11-01, 17:01)Michael Heidemann Wrote: [ -> ]No, if I change http: to https: I do not get any connection. Changed all back to http:.
cu
Mikeheide
DATHeader and all DAT/LDR/MPD files should be excluded from forced https
Pages: 1 2
