(2019-12-18, 14:22)Mihai Zop Wrote: [ -> ]Hi,
Lego Dragon Wing 9 x 6 it's not present in Studio software. It's found in 76119 Batmobile set. Would be nice to have it for designing batmobiles.
https://www.bricklink.com/v2/catalog/cat...2#T=C&C=11
Thank you!
SeaGer
This is a brand new part with a complicated geometry. It will take a while before someone decides to tackle it.
(2019-12-18, 17:23)Orion Pobursky Wrote: [ -> ]This is a brand new part with a complicated geometry. It will take a while before someone decides to tackle it.
Geometry is not that complex. But good photos are necessary, and they won't be available before set availability...
(2019-12-19, 6:50)Philippe Hurbain Wrote: [ -> ]Why did I miss New Elementary image??? (Flickr images are very interesting too). I'll give a shot at this...
I made some good quality photos with the background removed.
https://we.tl/t-JxEMd2503r
If you need more angles, tell me.
(2019-12-19, 8:43)Mihai Zop Wrote: [ -> ]I made some good quality photos with the background removed.
Most excellent, thanks!
One confirmation: is the outer rim usable with clips or is it a tad smaller?
(2019-12-18, 19:35)Philippe Hurbain Wrote: [ -> ]Geometry is not that complex. But good photos are necessary, and they won't be available before set availability...
Sorry, I must have goofed in the part number for my search... Indeed the sets are out!
(2019-12-19, 9:47)Mihai Zop Wrote: [ -> ]https://imgur.com/a/tINEfLI hope this answers you
No that's not what I meant. Question is, can I use the clip on outer rib? From your high resolution images I guess that the answer is no (loose connection), but...
(2019-12-19, 11:07)Gerald Lasser Wrote: [ -> ]and the curved outer edge is also 3.18, to allow further connections.
...I should also have read the text
(2019-12-19, 11:19)Philippe Hurbain Wrote: [ -> ]...I should also have read the text
https://imgur.com/a/aoEIAhO sorry, first time you said rim ☺️
How about this? The connection is very good
(2019-12-19, 11:42)Mihai Zop Wrote: [ -> ]https://imgur.com/a/aoEIAhO sorry, first time you said rim ☺️
Thanks!
Hopefully last question, can you measure the following values? Put it another way - overall dimension? is bar hole on grid?
(2019-12-19, 12:12)Philippe Hurbain Wrote: [ -> ]Thanks!
a - 6.4cm
b - 1.7cm
c - 1.2cm
Measured with a ruler. I cannot provide 2 decimals
(2019-12-19, 12:22)Mihai Zop Wrote: [ -> ]a - 6.4cm
b - 1.7cm
c - 1.2cm
Mmhhh.... now I have a problem, it doesn't really fit.
(2019-12-19, 17:42)Philippe Hurbain Wrote: [ -> ]Mmhhh.... now I have a problem, it doesn't really fit.
It doesn't fit where? Unfortunately I don't think I can help you more.
(2019-12-19, 23:23)Mihai Zop Wrote: [ -> ]It doesn't fit where? Unfortunately I don't think I can help you more.
I think he means that the numbers you gave don't match the relative dimensions in the photo, and cannot be made to match the photo.
(2019-12-20, 6:55)Philippe Hurbain Wrote: [ -> ]Yes, exactly!
I understand. Well, for now i cannot help you more. I cannot provide exact perspective with a phone camera. Maybe some photoshop could manipulate the photos i gave to the exact dimensions.
(2019-12-20, 10:41)Mihai Zop Wrote: [ -> ]I understand. Well, for now i cannot help you more. I cannot provide exact perspective with a phone camera. Maybe some photoshop could manipulate the photos i gave to the exact dimensions.
You don't have a flat bed scanner, do you? That would be the best solution. Otherwise I'll make do with your photos
(2019-12-20, 11:27)Philippe Hurbain Wrote: [ -> ]You don't have a flat bed scanner, do you? That would be the best solution. Otherwise I'll make do with your photos
I need to go back to work. I'll see what I can do the next days.
(2019-12-20, 12:18)Mihai Zop Wrote: [ -> ]I need to go back to work. I'll see what I can do the next days.
I attached a scanned pdf of the wing. I tried different scan options in this pdf. This is the best i can do. I hope de proportions are good
https://we.tl/t-3JlyXP7Y3K
Hi, any updates on this part? It seems like they didn't add it to the software. i was able to partially import it in part designer, but it's buggy and cannot snap it on other parts. Any chance of a file with the whole piece?
Thank you!
(2020-07-25, 22:20)Mihai Zop Wrote: [ -> ]Hi, any updates on this part? It seems like they didn't add it to the software. i was able to partially import it in part designer, but it's buggy and cannot snap it on other parts. Any chance of a file with the whole piece?
Thank you!
Did you install the latest
LDraw Parts Update (2020-01)? Part 38547 and all its subparts was issued in that release.
(2020-07-26, 6:47)Chris Dee Wrote: [ -> ]Did you install the latest LDraw Parts Update (2020-01)? Part 38547 and all its subparts was issued in that release.
Yeah, i missed that. Thank you so much, I was waiting for so long.
This looks so dope.
I need to finish the instructions now
