Hi there,
I'd like to contribute the six models 40190-40195 "Shell Ferrari series" of 2014:
40190 red Ferrari F138
40191 red Ferrari F12 Berlinetta
40192 blue Ferrari 250 GTO
40193 yellow Ferrari 512 D
40194 Finish line and Podium
40195 Shell Station
Unfortunately, there are some prints that I could not find / do not exist so far, and all stickers are missing. For easier access, I will upload each file in a separate post below this thread, and indicate missing prints/stickers as appropriate. Some parts have different Rebrickable/Bricklink vs. LDraw numbers - thank you Philippe for your hint how to find the correct parts.
As always: any suggestion is highly welcome.
Regards
Stefan
File should be OMR compliant.
Known issues: missing prints / stickers.
Done with LDCad 1.6c (Linux64).
Edit: Please find below the updated file with fixed front part with print. This updated file has "Known issues: missing stickers". The file attached to this post is kept for conversation understanding.
Edit2: Please find a newly updated version at the end of 40190.
Known issues: missing stickers.
Known issues: missing stickers, file contains embedded part which is already certified but still unofficial.
The printed front is in the library. It's not a sticker.
You should use 256, Rubber_Black on the tyres.
(2019-12-17, 17:40)Magnus Forsberg Wrote: [ -> ]The printed front is in the library. It's not a sticker.
Thank you Magnus, now all tires are Rubber_Black.
Indeed the white stripe is printed - unfortunately I could not find the 93589 Curved Tapered 4x2 part with white stripe in the official library or via Part Tracker.
Additionally it has a sticker with Shell and Ferrari logos, so I fixed "known issues".
Something I don't understand: the 93589 is in the official complete.zip file authored by you ("Author: Magnus Forsberg [MagFors]" and "!LDRAW_ORG Part UPDATE 2013-02"), but according to today's Part Tracker web search it is not official.
Am I doing something completely wrong here?
(2019-12-17, 19:19)Stefan Frenz Wrote: [ -> ]...
No, nothing's wrong here. This happens if a part is recycled due to being patterned or improved.
This is indicated on the Parts Tracker with the status "F"
If a part is submitted again (through the PT-Admin), an additional History Line is necessary, in this case it says:
0 !HISTORY 2018-02-28 [Sirio] Modification for front pattern
(2019-12-17, 20:11)Gerald Lasser Wrote: [ -> ]No, nothing's wrong here. This happens if a part is recycled due to being patterned or improved.
Thank you very much for explanation, Gerald.
I'm sorry if I took the wrong words - I didn't mean "here is something wrong", I meant "I am doing something wrong". The latter clearly is the case.
Unfortunately, even with your hints I didn't get the white printed stripe included in 93589 (tried downloading the unofficial file with subfiles, including them in the Unofficial directory of LDraw, added this directory to LDCad configuration both before and after all other part directories). Is the printed white stripe not in the file 93589 but somewhere else? Sorry for being interested and slow-witted at the same time.
(2019-12-17, 20:31)Stefan Frenz Wrote: [ -> ]added this directory to LDCad configuration both before and after all other part directories). Is the printed white stripe not in the file 93589 but somewhere else?
It's usually easier to just get all the unofficial files and add it to LDCad as a second 'complete.zip'.
attachment=4469]
edit: you might want to move it to the top, if you want duplicate unoffical content to 'override' offical ones.
(2019-12-17, 20:45)Magnus Forsberg Wrote: [ -> ]Direct link [...]
Thank you, Magnus - I was assuming, searching "93589" in the "lookup" field would lead to all parts starting with 93589, which seems not to be the case. Searching "Curved Tapered" would have given me the 93589p01 - sorry. The "pattern summary" and "sticker summary" is completely new to me, so for the future I will have a look at those summaries and will search for names additionally to numbers, thanks again!
(2019-12-17, 20:55)Roland Melkert Wrote: [ -> ]It's usually easier to just get all the unofficial files and add it to LDCad as a second 'complete.zip'.
Thank you so much, Roland!
This is much easier for me now!
With the complete ldrawunf.zip file, all 93589 variants appear instantly.
With both of your suggestions I accomplished replacing the part.
Thank you for helping and being patient.
Attached is the updated file.
(2019-12-17, 16:25)Stefan Frenz Wrote: [ -> ]File should be OMR compliant.
Sorry, it was not OMR-compliant. The embedded sub-part was not named correctly. Attached is an updated version.
Sorry, it was not OMR compliant. Now fixed sub-file naming, attached is an updated version.
Fixed OMR naming rule for main part.
