Are
these useful parts in LDRAW at all?
They have been out for a while now and I wanna use them in LDRAW because they're very useful.
They first appeared in the set 76122 Lego Batcave Clayface Invasion.
I know I can search through the ldraw parts library in different ways or use the parts tracker but the parts are just grouped as one part on sites such as
brickset so it's impossible to know the parts numbers or names.
Regards, Snipe.
(2019-11-02, 21:43)Magnus Forsberg Wrote: [ -> ]No, they're not.
Only decent images I know of are at New Elementary
https://www.newelementary.com/2019/10/ne...-2019.html
It would be hard to do anyone of them without having it in hand. Pure guesswork.
I do have the accessory pack -10 (
6266155) at home, but not the 11
This is neither available on BL nor at TLG direct. Just found it on Brickowl...and ordered the last bag available...
Let's wait for them to arrive for measurement and comparative pics.
(2019-11-02, 23:02)Gerald Lasser Wrote: [ -> ]I do have the accessory pack -10 (6266155) at home, but not the 11
Need to update you on this order...
... I still don't have it. The seller on Brickowl is not responding... since the order status was changed to processing... so, let's see if the parts will finally turn up.
(2019-12-05, 22:37)Gerald Lasser Wrote: [ -> ]Need to update you on this order...
Look what I got!
The original Seller on BrickOwl did not ship... So I finally found a seller on BL and got it from there
attachment=4640]
While I am working on it, could you start thinking of the names...
attachment=4662]
A: Palte (?) 1 x 2 with
B: Plate 1 x 1 Hexagonal with Bar on bottom and Side
C: Plate 1 x 1 Ocatagonal with Studs on Both Sides and Two Bars at 90 Degrees
D: Plate 1 x 1 Hexagonal with Studs on Both Sides and Three Bars at 120 Degrees
E: Parabolic Reflector [Size] with Three Struts
F: Minifig Gun...
G: Circular Saw...
Which Category?
Thanks!
I don't see these as plates since they have no underside antistuds. Bricklink calls them weapons, but I don't see them as such except for the gun (doh!) and possibly the saw...
https://www.bricklink.com/catalogItemInv.asp?P=50018
Category is Minifig accessory imho.
(2020-01-15, 14:56)Philippe Hurbain Wrote: [ -> ]I don't see these as plates since they have no underside antistuds.
We allready have plenty of similar parts, without top or bottom stud.
11609, Plate 1 x 1 Round with Five-Pointed Star Top and Pin Hole Arm
25893, Plate 1 x 1 Round with Horizontal Handle Below
15470, Plate 1 x 1 Round with Swirled Top
(2020-01-15, 15:50)Magnus Forsberg Wrote: [ -> ]We allready have plenty of similar parts, without top or bottom stud.
Yeah, but 11609 and 15470 really have the shape of a Plate 1 x 1 Round with modified top. It's mode questionnable for 25893 - isn't this rather a bar with side stud?
Gun is done.... Paraplic Reflector polishing and Circular Saw from scratch...
attachment=4858]
Finally done!
Now let's see, origins and names, that's to come now!
REndered with "Metallic Silver", the Flat Silver Colour of Studio does not look nice...
attachment=4867]
(2020-02-16, 17:39)Gerald Lasser Wrote: [ -> ]Finally done!
Here's my suggestion for these "tools":
50018a Minifig Tool Hexagonal with Opposing Studs and 3 Ribbed Handles at 120 Degrees
50018b Minifig Tool Nozzle with Opposing Studs with Angled Ribbed Handle and Rear Bar Handle
50018c Minifig Tool Hexagonal with Hollow Stud with Perpendicular Bar and Ribbed Handle
50018d Minifig Tool Octagonal with Opposing Studs and Perpendicular Bars
50018e Minifig Tool Peanut Shaped with Hollow Stud and Offset Bar
50018f Minifig Tool Hemisphere with 3 Ribs and Hollow Stud
50018g Minifig Tool Circular Tooth Blade with Cover with Opposing Studs and Bar
"Minifig Tool [shape] with Stud, Bar, Handle" (always in the same order; stud, bar, handle).
