2019-10-15, 16:49
Hello everyone on the board, just wondering is there a way to add a ground plane in the editing screen? I meant a sturdy ground base to lay the model on?
(2019-10-15, 16:49)Richard L. West Wrote: [ -> ]Hello everyone on the board, just wondering is there a way to add a ground plane in the editing screen? I meant a sturdy ground base to lay the model on?
(2019-10-15, 16:57)Orion Pobursky Wrote: [ -> ]For which editor?I actually meant the LDraw all in one editor Orion, Sorry for the confusion. What size base plate should I use for the Main Ground plane? Does it really matter that much? I should have explain myself better in the last message.
In a pinch you could just put a large base plate in at 0,0,0 and delete it when you're done.
(2019-11-04, 2:56)Richard L. West Wrote: [ -> ] I actually meant the LDraw all in one editor Orion, Sorry for the confusion. What size base plate should I use for the Main Ground plane? Does it really matter that much? I should have explain myself better in the last message.Do you mean MLCad? (Is there a black Jeep as splash screen when you start it?)
(2019-11-04, 11:05)Lasse Deleuran Wrote: [ -> ]Do you mean MLCad? (Is there a black Jeep as splash screen when you start it?)
If so, then I recommend adding a big base plate and set its color to transparent. You can then remove this once your model is finished.
(2019-11-04, 2:56)Richard L. West Wrote: [ -> ] I actually meant the LDraw all in one editor Orion, Sorry for the confusion. What size base plate should I use for the Main Ground plane? Does it really matter that much? I should have explain myself better in the last message.Just adding some background: there is no such thing as THE LDraw all in one editor: the all-in-one installer provides three editors, LDCad, LeoCAD and MLCad (listed in order of personal preference!!!).
