2019-10-07, 18:28
with this LDPE release it is possible to open multiple files in one go, invert the mouse wheel zoom direction and there are some other features, too
Changelog:
(5 new features and 2 bug fixes)
What will the next release 0.8.50 deliver? clever auto-completion / context menu for the text editor / usability.
System Requirements:
Minimum System Requirements:
Changelog:
- ...invert the mouse wheel zoom direction (Tools... -> Options... -> Customise Shortkeys).
- ...open multiple files in one go.
- ...use a shortcut to reset the manipulator to the origin and world orientation ("R" key).
- ...see the coordinates of up to 4 selected vertices in the status bar (there is some logic behind their displayed order. The topmost vertex is displayed first.).
- ...benefit from the automatically deactivation of "Add..." when you focus or select something in the text editor.
- The scale tool and other tools displayed the manipulator with "global" coordinates when "local" coordinates were active.
- There was a missing comma in the selection info on the status bar.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
