Hi Team,
I've created Tail 2340p030 but the surfaces seem to lose their relationships (?) when imported to Blender using the LDR import plugin.
The part was created using LDPE to create left and right templates for use in LDPC, then patterns created. These left and right patterns where then added to the subfile of 2340s01.
attachment=4060] [
attachment=4061]
The created part imports into Stud.io correctly but subsequent export/import into Blender seems to break the part apart.
attachment=4062]
What term/technique have I overlooked or misunderstood?
I've actually created all of the "Canada" series printed bricks and am happy to submit them once this piece is complete.
Thanks in advance.
Adam
(2019-09-30, 22:44)AdamM Wrote: [ -> ]... imported to Blender using the LDR import plugin.
Please, define Blender add-on you use?
(2019-09-30, 23:42)Eugen Wrote: [ -> ]Please, define Blender add-on you use?
I'm using the TobyNelson plug-in (TobyLobster I assume).
(2019-09-30, 22:44)AdamM Wrote: [ -> ]Hi Team,
Thanks in advance.
Adam
Hello Adam;
Welcome to LDraw!
You did not use the sub-part 2340s01.dat in your code.
May be, this could solve your problem.
Try to do so.
Further more - I suggest the usage of primitives for your pattern.
Something like that:
1 4 3 35 -15 0 1 0 -2.7 0 0 0 0 2.7 48\2-4ring6.dat
1 9 3 35 -15 0 1 0 -17.461323 0 7.232717 7.232717 0 17.461323 48\1-4ndis.dat
1 9 3 35 -15 0 1 0 7.232717 0 17.461323 17.461323 0 -7.232717 48\3-16ndis.dat
1 9 3 35 -15 0 1 0 -17.461323 0 -7.232717 7.232717 0 -17.461323 48\2-4ndis.dat
1 4 3 35 -15 0 1 0 -2.7 0 0 0 0 -2.7 48\11-24ring6.dat
1 12 3 35 -15 0 1 0 0 0 16.2 -16.2 0 0 48\1-8chrd.dat
1 11 3 35 -15 0 1 0 11.45513 0 11.45513 -11.45513 0 11.45513 48\1-12chrd.dat
1 9 3 42.871 -24.58 0 1 0 -.182628 0 .238006 -.238006 0 -.182628 3-8chrd.dat
1 10 3 42.871 -24.58 0 1 0 -.182628 0 .238006 -.238006 0 -.182628 3-8ndis.dat
1 9 3 39.536 -23.987 0 1 0 -.23 0 .11 -.11 0 -.23 3-8chrd.dat
1 10 3 39.536 -23.987 0 1 0 -.23 0 .11 -.11 0 -.23 3-8ndis.dat
The leave itself can be splitted to half in it's Y-symetry line and subparted and simple mirrored
have a good time here
Uli
[attachment=4079 Wrote:Ulrich Röder pid='34147' dateline='1569935437']
Hello Adam;
Welcome to LDraw!
Try to do so.
Uli
Thanks so much.
I ended up playing around a little and settled on the following code
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\2340s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\canadalogoleft.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\canadalogoright.dat
attachment=4079]
Another part authoring technique learnt, thank you.
Cheers
Adam
