2019-09-11, 21:06
Currently, the following text exists in the sticker spec:
This proposal is to change the above text to instead read:
Quote:The sticker pattern is modelled in its true colours; they are not modifiable from the outside. All printed colours of the pattern must be matched, and the background (non-printed portion) of the pattern must use colour 16. Mimicking a colour by blending in the background colour of the part underneath using colour 16 is not allowed.
Quote:The sticker pattern is modelled in its true colours; they are not modifiable from the outside. All colours of the top surface must be matched, and the back side and sides of the sticker must use colour 16. Print on a transparent plastic sticker sheet should use colour 16 on the transparent part of the top surface.
