Guys,
goes the hole in 11062 - Lamppost 2 x 2 x 7 with 4 Base Flutes through the entire part? How thick is this hole - 3 LDU?
Thx,
(2019-09-11, 20:46)Willy Tschager Wrote: [ -> ]Guys,
Willy, the hole is about 12 mm deep, it does not go through all the way.
The stop-ring is at 2 mm
Diameter is hard to validate, but the inner diameter of the hole is 3,2mm 8 LDU, with the stop ring it is reduced usually to 6 LDU, right? It is definitely closer to 2,4 mm than to 1,2 mm
PS: I had to open the Winter Fire Station from Billund, to get the part
(2019-09-11, 22:20)Gerald Lasser Wrote: [ -> ]PS: I had to open the Winter Fire Station from Billund, to get the part
One day you will tell me where you get the will power to open a MISB
(2019-09-12, 8:46)Willy Tschager Wrote: [ -> ]One day you will tell me where you get the will power to open a MISB
You can only do that if the force is with you
