A minor one: if I click in the loockup box (of the "Go" button) of PT submit page, the file submit browse file window is popped.
(2019-09-11, 1:44)Orion Pobursky Wrote: [ -> ]This should be fixed.
Are you fixing it, or shall I? I think this is a result of the re-styling.
(2019-09-11, 6:00)Chris Dee Wrote: [ -> ]Are you fixing it, or shall I? I think this is a result of the re-styling.
Orion implies that he changed things that should fix the issue... and that did the trick!
This was a bug in my JavaScript. I identified the problem and it is now fixed.
(2019-09-11, 12:06)Orion Pobursky Wrote: [ -> ]This was a bug in my JavaScript. I identified the problem and it is now fixed.
OK - so when you wrote 'should be fixed' you meant 'has been fixed' :-)
(2019-09-11, 13:19)Chris Dee Wrote: [ -> ]OK - so when you wrote 'should be fixed' you meant 'has been fixed' :-)
Oh. I was confused by your confusion but now I see how this could be confused.
