2019-09-01, 16:37
Hey,
here is a new LDPartEditor release which let you swap the mouse button layout (for rotation and translation in the 3D view).
[attachment=3976]
I also provided an alternative 64-bit linux release since I had some problems with LDPE on another linux distro (Ubuntu).
Changelog:
(3 new features and 2 bug fixes)
What will the next release 0.8.49 deliver? open multiple files / clever auto-completion / context menu for the text editor / usability.
System Requirements:
Minimum System Requirements:
[attachment=3976]
Changelog:
- ...swap the middle and right mouse button assignment (view translation and view rotation)
- ...get the PNG textures from the PartsTracker when you are using the PartReview tool.
This is useful for the review of !TEXMAP patterns.
- ...configure a viewport scale factor (this is only necessary for 4K screens with a high pixel density)
- Display issues on a 3840x2160 display: empty regions & misplaced cursor.
- The vertex window popup was causing an internal error (with no negative side effects for the user).
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
