2019-08-28, 16:27
Attached is a sample of hose routing from a current project.
Here's the scale from the instructions:
[attachment=3971]
Ribbed hose 1 (the 3 middle hoses) are magenta dotted in the instructions. The online inventory for this part this would correspond to Flat Silver Hose, Ribbed 7mm D. 9L
Ribbed hose 2 (the shorter hose to the right) is orange dotted. The online inventory for this part this would correspond to Flat Silver Hose, Ribbed 7mm D. 7L
Ribbed hose 3 (the longer hose to the left) is green dotted. The online inventory for this part this would correspond to Flat Silver Hose, Ribbed 7mm D. 18L
I have a couple of issues:
- The hoses overlap other components. How do others deal with this issue?
- The hose lengths in the instructions vs. actual model appear to not be correct, especially for hose 2. I have this set (8458) but it's packed up somewhere and I can readily verify.
Note: the attached MPD will only work in LDCad since I have fallback code turned off.
[attachment=3971]
