(2019-08-10, 10:34)Willy Tschager Wrote: [ -> ]Looks like LDCad is not supporting speckle colors:
https://brickset.com/colours/type-Speckle
They should render as normal 'plastic' without the specs.
Or do you mean they are missing in one of the bins?
(2019-08-12, 18:04)Roland Melkert Wrote: [ -> ]They should render as normal 'plastic' without the specs.
Both. I wish they were present and render as speckle. And since we are there I wish there were no dithered colors in the bin. They just distract.
(2019-08-13, 6:39)Willy Tschager Wrote: [ -> ]And since we are there I wish there were no dithered colors in the bin. They just distract.
There is an option for that in the settings (probably in LDraw section) - and yes, for me too this option should be off by default.
Speaking of colors, I would like to have a search and/or a filter like for parts bin...
(2019-08-13, 7:48)Philippe Hurbain Wrote: [ -> ]There is an option for that in the settings (probably in LDraw section) - and yes, for me too this option should be off by default.
Found it! I also suggest that it is turned off by default.
(2019-08-13, 6:39)Willy Tschager Wrote: [ -> ]I wish they were present and render as speckle.
They are missing in the bins because there are currently no groups whom filter on them. The because they don't have one of the internal special characteristics (plastic, metal, chrome, etc)
You can however get them in the bin by creating a custom group filtering on all known properties so you are left with the glitter and speckle ones.
Put the below content in a .cbg file in (%appdata%/LDCad/colorbin/default) and add a reference to it in root.cbg
[options]
kind=filter
caption=Other
description=Everything else
sortOn=number
<filter>
include all
exclude plastic
exclude chrome
exclude pearl
exclude metal
exclude matteMetal
exclude system
exclude rubber
Be sure to do this while LDCad is closed.
As for rendering them this has to wait on the 2.0 engine as it's very hard to do in the current (fixed pipeline) OpenGL setup.
