It looks like there is a problem with LDCad 1.6c when creating flexible parts.
For example, with flexible axles:
When i open the created file with LPub2.3.6 I got an error message that the file 's / faxle1.dat' can not be found.
The file is contained in both the complete.zip and the unpacked files.
If you open the file with LPub 2.3.12, there are no problems.
Flexible axles created with LDCad 1.6b are no problem, neither in 2.3.6 nor in 2.3.12.
Have attached two test files.
(2019-08-01, 18:43)Johann Eisner Wrote: [ -> ]Flexible axles created with LDCad 1.6b are no problem, neither in 2.3.6 nor in 2.3.12.
I changed the template for the technic flex axle.
It now uses caps that can snap and don't bend.
The problem dependency is from that new cap it seems, source for "ldcFlexAxleCap.dat"
0 Donor for technic flexible axle cap
0 Name: ldcFlexAxleCap.dat
0 Author: LDCad
0 !CATEGORY LDCad donor
0 Unofficial part
1 16 0 0 0 1 0 0 0 5 0 0 0 1 stud3a.dat
1 16 0 4 0 0 1 0 -1 0 0 0 0 1 s\faxle1.dat
0 !LDCAD SNAP_CYL [gender=M] [caps=one] [secs=R 4 20] [slide=true]
The two type 1 lines get inlined during generation so LPub doesn't need access to ldcFlexAxleCap.dat, but it might get confused by s\ references outside a library location?
(2019-08-01, 19:30)Roland Melkert Wrote: [ -> ]I changed the template for the technic flex axle.
0 Author: LDCad
0 Unofficial part
Could be so, the axis is indeed displayed correctly. What I also noticed when opening the 1.6c file in 1.6b, missing the ends of the axis.
(2019-08-01, 19:33)Johann Eisner Wrote: [ -> ]What I also noticed when opening the 1.6c file in 1.6b, missing the ends of the axis.
If you use 1.6b with its original support files it will be missing the ldcFlexAxleCap.dat file. LDCad doesn't render the fallback code it will always regenerate for which it needs the donor files.
You could copy the ldcFlexAxleCap.dat from 1.6c's donor folder into the 1.6b one if you want to use from that version.
(2019-08-01, 19:33)Johann Eisner Wrote: [ -> ]Could be so, the axis is indeed displayed correctly.
You could probably solve the lpub problem by not inlining the caps and adding ldcFlexAxleCap.dat to Lpub's custom parts location.
To disable the inlineing change
inlineRef=true
to
inlineRef=false
in the technicFlexAxle.ldr template and or your mpd's. It will need to regenerate/resave before LPub can use it though.
(2019-08-01, 19:46)Roland Melkert Wrote: [ -> ]You could probably solve the lpub problem by not inlining the caps and adding ldcFlexAxleCap.dat to Lpub's custom parts location.
inlineRef=true
to
inlineRef=false
I'm sure I'll stay at 1.6c
inlineRef=true
to
inlineRef=false
I have solved the problem now once with the good old import function of MLCad.
faxle1.dat imported and then inserted at the flexible axle instead of the s / faxle1.dat.
