2019-07-29, 19:28
Hey,
large colour numbers were not compatible with LDPartEditor. It is now corrected.
There is basically no limit anymore (don't try the 32-bit integer maximum
Changelog:
(1 bug fix)
With this release the following critical issue is fixed:
What will the next release 0.8.48 deliver? clever auto-completion / context menu for the text editor / usability.
System Requirements:
Minimum System Requirements:
Changelog:
(1 bug fix)
- High colour numbers prevent the colour dialog from showing up.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
