I am thinking of recreating this in native LDraw format:
http://lib.povray.org/searchcollection/i...Tag=SharkD
I plan on using bitmap textures for the surface features just to make things easier. I have one question though: does LDraw support repeating textures, or are they just one-offs? Thanks.
(2019-07-14, 13:29)Michael Horvath Wrote: [ -> ]I am thinking of recreating this in native LDraw format:
LDraw itself doesn't support textures (or backgrounds for that matter).
All parts, prints and stickers need to be created through primitives in the form of colored lines, triangles and squares.
There are some programs used to create models that can support backgrounds through special metacommands/functions which are not part of LDraw.
There are also programs through which you can create the print/sticker (either by hand or through conversion) where you can you use the original file/rendering/photo for reference only.
(2019-07-21, 9:55)Rene Frijhoff Wrote: [ -> ]LDraw itself doesn't support textures (or backgrounds for that matter).
Thanks. For some reason I thought LDraw supported bitmap textures too. The center road stripe is going to be non-trivial to create without repeating textures.
(2019-07-21, 13:18)Michael Horvath Wrote: [ -> ]Thanks. For some reason I thought LDraw supported bitmap textures too. The center road stripe is going to be non-trivial to create without repeating textures.
LDraw does support textures via the !TEXMAP extension:
https://www.ldraw.org/documentation/ldra...pping.html
It's intended for patterned parts but I don't see any reason it couldn't apply to a model file as well.
(2019-07-21, 23:25)Orion Pobursky Wrote: [ -> ]LDraw does support textures via the !TEXMAP extension:
Which method would be best to map a single flat texture to a single triangle? Imagine a short section of road made of four vertices and two triangles. (The triangles need not be coplanar.) The texture should be oriented correctly in the direction of travel.
Can textures repeat? That would be very useful. Typically, the parametric functions I will be using create shorter road sections where the curvature is greater, and longer sections where the curvature is minimal. But the textures themselves need to always remain the same scale.
