Full Version: Stickers for set 10266
Hi all,
I am making progress in creating the stickers for set 10266 (the Lunar Lander)
But now I am totally in the dark for the partnumber.
I submitted 3 simple stickers the the tracker, but apperntlythe part number is still wrong.
Since I still do not own the set I am working from images of the stickersheet found online.
I must have seen atleast one version that had 134071 on it somewhere, so I took that as partnumber with letter suffix, a, b, c... h, i  for the sticker number.
Now I found another scan of the stickersheet that has number 65305/6279911 on it.
Please enlighten me on what number to use and how to name these parts?
Judging Magnus' hold comment:
https://www.ldraw.org/article/339.html
"The part number for the flat sticker part is the SKU from the edge of the sticker sheet with a single letter suffix. Each different sticker from a single sheet should have a unique suffix. [...] Stickers from sheets with combo 5-digit/7-digit numbers should use the 7-digit number. "
It must be 6279911?
So sticker number 8, 9 and 13 should be 6279911h, 6279911i and 6279911m
Oh, and can the parts with the wrong number be deleted please:
134071a08.dat
134071h.dat
134071i.dat
134071m.dat
Or rename the last 3?
(2019-07-08, 13:32)Jaco van der Molen Wrote: [ -> ]It must be 6279911?
Yes. This is the correct number.
(2019-07-08, 13:40)Orion Pobursky Wrote: [ -> ]Yes. This is the correct number.
Ok, thanks. Can my submits be renamed? Or delete them, then I will submit correct ones.
(2019-07-08, 13:49)Jaco van der Molen Wrote: [ -> ]Ok, thanks. Can my submits be renamed? Or delete them, then I will submit correct ones.
Yes.
Send a mail to [email protected] and ask for a renumbering.
Did you email Chris for the deletion of these:
parts/134071a08.dat
Sticker 2.9 x 1.4 with Black and Gold Straight Planes
[Image: red1x1.gif] 1 'hold' vote. (HX)
parts/134071h.dat
Sticker 2.9 x 1.9 with Black and Gold Straight Planes
parts/134071i.dat
Sticker 2.9 x 1.9 with Black and Gold Diagonal Planes
[Image: 1x1white.gif] Needs more votes. (X)
parts/134071m.dat
Sticker 3.9 x 2.9 with Black and Gold Straight and Diagonal Planes
(2019-07-16, 4:19)Willy Tschager Wrote: [ -> ]Did you email Chris for the deletion of these:
parts/134071a08.dat
parts/134071h.dat
parts/134071i.dat
parts/134071m.dat
Yes, delete 134071a08.dat
And rename the other 3 or delete them too, so I can submit the correct ones.
