2019-06-08, 9:43
with this release I replaced the http-interface to ldraw.org (required for the download of ldconfig.ldr and parts from the tracker) with a solution which uses https.
I also provided an alternative 64-bit linux release since I had some problems with LDPE on another linux distro.
Changelog:
(1 new feature and 3 bug fixes)
What will the next release 0.8.47 deliver? clever auto-completion / context menu for the text editor / usability.
System Requirements:
Minimum System Requirements:
Changelog:
- ...see some hints on the configuration screen when you are launching LDPartEditor for the first time.
- The PartReview tool got broken by the introduction of HTTPS on the Parts Tracker.
- The access to categories.txt and ldconfig.ldr got broken by the introduction of HTTPS on LDraw.org
- The program did not really quit when the configuration screen was cancelled.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
