Full Version: Wikipedia
Pages: 1 2 3 4
(2019-06-18, 0:05)Orion Pobursky Wrote: [ -> ]Why are we using POV when Studio looks just as good at a fraction of render the time
Interesting... for me Studio takes significantly longer than POV (but with a better quality). Maybe my machine needs a new graphics board?
(2019-06-18, 5:35)Philippe Hurbain Wrote: [ -> ]Interesting... for me Studio takes significantly longer than POV (but with a better quality). Maybe my machine needs a new graphics board?
OK
Here a render from Studio (Photoreal, very high)
[Image: 36040683xt.png]
(2019-06-18, 10:44)Johann Eisner Wrote: [ -> ]OK
Which render engine is studiio using?
Is it still blender? As this image want me to revisit researching exporting to blender files again Smile
(2019-06-18, 19:38)Roland Melkert Wrote: [ -> ]Which render engine is studiio using?
In Photoreal setting Studio use the eyesight renderer.
here are the 2 currently available importers:
https://wiki.ldraw.org/wiki/Blender
(2019-06-18, 20:04)Steffen Wrote: [ -> ]here are the 2 currently available importers:
I know about the model importers but while working on the POV-Ray animation export of LDCad I also considered exporting to blender files but its format isn't trival.
(2019-06-18, 2:32)Travis Cobbs Wrote: [ -> ]I added support for command line exports to LDView 4.3. (See LDView's Help.html#ExportFilename.)
Despite what I said before, it is likely that there will eventually be an LDView 4.4, but I have a texture-related bug that I'm pretty sure that I introduced that needs to be fixed first, and I haven't been able to figure it out yet.
Do you mind if I write up a list of suggestions? They should not be complicated to implement. Mostly they deal with defining and not overwriting variables.
(2019-06-17, 6:49)Johann Eisner Wrote: [ -> ]Hi
Here two fast renders with povray from the car.ldr.
Resolution is only 1920x1080 for this test.
Light and floor has been changed a little bit for the standard export of LDView.
This model is very........... basic............. but okay if that's what you want.
But, is there maybe a licensing issue with that model? Who created it in the first place? Wikipedia will delete non-copyleft images unless there is a fair use rationale. I think it would be better if the model itself was released under a copyleft license, too.
(2019-06-19, 4:37)Michael Horvath Wrote: [ -> ]This model is very........... basic............. but okay if that's what you want.
This is the car.ldr from James Jesiman.
I used this file because of the disskusion above.
As already mentioned, if a larger model is preferred, I can gladly provide one of mine.
(2019-06-19, 4:34)Michael Horvath Wrote: [ -> ]Do you mind if I write up a list of suggestions? They should not be complicated to implement. Mostly they deal with defining and not overwriting variables.
I certainly don't mind. I definitely pay attention to suggestions, but I also make no promises about them.
Pages: 1 2 3 4
