Full Version: Help fixing some parts i uploaded to part tracker.
guys i have up loaded some design to part tracker, several of them have observation. i was wondering if some one could help me with some of the comments and find a easy quick way to fix the issues.
i have several models that UR it letting me know the following:
Quote:At Wed May 8 13:15:01 2019, the following review was posted:
Reviewer: UR
Certification: hold
Comments:
...also here...same problems....mismatching points...overlaps...
...T-junctions
edger2 results , unmatched edges only:
2 4 5.2 6.55488 -16.55488 5.7 5.96091 -15.96091
2 4 19.99 3.28098 -13.28098 20 0 -10
2 4 -17.52 5.38108 -15.38108 -17.69 3.30219 -13.30219
2 4 -20.01 12.6855 -22.6855 -20 14.92702 -24.92702
2 4 17.59 3.86787 -13.86787 17.66 5.46594 -15.46594
2 4 20 10.63489 -20.63489 19.99 8.358 -18.358
2 4 19.99 5.81242 -15.81242 19.99 3.28098 -13.28098
2 4 -17.69 3.86787 -13.86787 17.59 3.86787 -13.86787
2 4 -20.01 10.67731 -20.67731 -20.01 12.6855 -22.6855
2 4 3.75 3.87495 -13.87495 -17.69 3.86787 -13.86787
2 4 -17.52 10.79045 -20.79045 -17.52 5.49422 -15.49422
2 4 19.99 8.358 -18.358 19.99 5.81242 -15.81242
2 4 16.76 5.87606 -15.87606 17.64 6.24375 -16.24375
2 4 -5.19 12.44508 -22.44508 -5.21 6.67509 -16.67509
2 4 19.99 14.73611 -24.73611 20 10.63489 -20.63489
2 4 -5.21 6.67509 -16.67509 -5.23 5.28209 -15.28209
2 4 17.56 5.28209 -15.28209 17.59 3.86787 -13.86787
2 4 5.21 5.28209 -15.28209 5.2 6.55488 -16.55488
2 4 5.2 12.42387 -22.42387 5.21 13.15219 -23.15219
2 4 -5.23 13.2229 -23.2229 -5.19 12.44508 -22.44508
2 4 -20 14.92702 -24.92702 -20 20 -30
2 4 -11.53 -.00707 -9.99293 -20 0 -10
2 4 5.21 13.15219 -23.15219 5.21 5.28209 -15.28209
2 4 -5.23 5.28209 -15.28209 -5.23 13.2229 -23.2229
2 4 5.21 5.28209 -15.28209 -5.23 5.28209 -15.28209
2 4 -17.69 3.30219 -13.30219 -17.69 3.86787 -13.86787
2 4 17.66 5.46594 -15.46594 17.59 3.30219 -13.30219
2 4 -17.49 9.71565 -19.71565 -17.52 10.79045 -20.79045
2 4 17.59 3.30219 -13.30219 17.56 5.28209 -15.28209
2 4 20 0 -10 -11.53 -.00707 -9.99293
2 4 -5.23 5.28209 -15.28209 -16.37 5.27502 -15.27502
2 4 -17.52 5.49422 -15.49422 -17.49 9.71565 -19.71565
2 4 -16.37 5.27502 -15.27502 5.21 5.28209 -15.28209
2 4 -20 0 -10 -20.01 10.67731 -20.67731
2 4 17.59 3.86787 -13.86787 13.77 3.87495 -13.87495
2 4 -17.69 3.86787 -13.86787 -17.52 5.38108 -15.38108
2 4 5.2 6.55488 -16.55488 5.2 12.42387 -22.42387
2 4 13.77 3.87495 -13.87495 3.75 3.87495 -13.87495
2 4 20 20 -30 19.99 14.73611 -24.73611
i was recommended to use edger2
Quote:check by yourself with edger2 "unmatched edges only" and T-junction finder (find only)
i did run it with -u+ parmeter is this the one he is mentioning? and regarding the t-juntcion what i should be doing?
when i run edger2 with the -u+ parameter the result was the same file with lines in red. what should i be fixin all this by hand? or what i should be doing. and how.
Quote:==============================
A novote review was posted for file parts/3039p16.dat 'Slope 45° 2 x 2 with Headlights Print' by user Philo.
See <http://www.ldraw.org//cgi-bin/ptdetail.c...039p16.dat>
A new version of file parts/3039p14.dat 'Slope Brick 45  2 x  2 with White "74" Pattern' was submitted by user tatubias.
See <http://www.ldraw.org//cgi-bin/ptdetail.c...039p14.dat>
A new version of file parts/3039p16.dat 'Slope Brick 45  2 x  2 with Headlights Pattern' was submitted by user tatubias.
A new version of file parts/3039p50.dat 'Slope Brick 45 2 x 2 with RoboForce Red Chevron and Yellow Eye Pattern' was submitted by user tatubias.
See <http://www.ldraw.org//cgi-bin/ptdetail.c...039p50.dat>
A hold review was posted for file parts/3039p13.dat 'Slope Brick 45  2 x  2 with White "3" Pattern  ' by user UR.
See <http://www.ldraw.org//cgi-bin/ptdetail.c...039p13.dat>
A hold review was posted for file parts/3039p50.dat 'Slope Brick 45 2 x 2 with RoboForce Red Chevron and Yellow Eye Pattern' by user UR.
i have being working on the part 3039p016.dat that had several issues.
i have re drawed all again from scratch and using edger2 i was able identify the issues on the design and fix them using LD Pattern creator. its a PITA work.
Edger2 its letting me know the following.
Note i have commented the main brick so chech this piece only.
Quote:0 // Unmatched edges
2 4 -20 0 -10 -20 20 -30
2 4 -20 20 -30 20 20 -30
2 4 20 0 -10 -20 0 -10
2 4 20 20 -30 20 0 -10
[Image: frQmbXB.png]
im uploading the 3039p16_fix.dat file that it letting me know that i have 4 Unmatched edges found but i dont know how to fix this issue.
also im attaching the original file made on LD Pattern.
if some one can help me to get rid off the last things that are wrong i will be glad.
How do i un match any vertex or lines that are in the border of the template.
Hi Victor,
Edge of pattern are obviously unmatched... Only mismatches appearing in the middle of the pattern need to be fixed. Or to say it another way: your pattern is great!
(2019-05-09, 18:47)Philippe Hurbain Wrote: [ -> ]Hi Victor,
Thank you philo i was going to burn my.pc.
I did rralize that when i was gererating the triangles sometimes the aplication did not click where it should be (ussually when you are making fast drawinngs) so that why i had those mistakes.
Regarding the red borders unmatched i was thinking the same but as all is new and it has so many things to learn to help ldraw i did not make the suppositions.
Today i will finis to fix the other designs and i will be uploading it to part tracker.
