2019-04-30, 0:32
![[Image: bA5cfXt.png]](https://i.imgur.com/bA5cfXt.png)
Set: 8054 - Universal Building Set with 4.5v motor Model A
OMR Compliant: Yes
Missing: Nothing
CAD: LDcad 1.6b As it should be
![[Image: wink.png]](https://forums.ldraw.org/images/smilies/wink.png)
Comments: This kit was my first Lego technic kit. i really love it. i still have it
(2019-04-30, 0:32)Victor Di Rienzo Wrote: [ -> ]OMR Compliant: Yes
(2019-05-25, 4:38)Charles Farmer Wrote: [ -> ]When I check it, is says it is not OMR compliant. Perhaps because you did not check for ~Moved files? That happened to me too, until Johann Eisner pointed me to check some additional checkboxes in the settings menu of MPDcenter:
Also, the naming of the subfiles was not correct. I fixed this, see attachment
For some reason, your renders do not show the rubber bands. I don't know why that it, because when I make a render (using LDview and PovRay), these rubber bands appear normally.
Nice model BTW, really classic
Quote:NON OMR HEADER
0 FILE 8054 - Universal Building Set with 4.5v motor Model A.ldr
0 8054 - Universal Building Set with 4.5v motor Model A
0 Name: 8054 - Universal Building Set with 4.5v motor Model A.ldr
0 Author: Victor Di Rienzo [tatubias]
0 !LDRAW_ORG Model
OMR HEADER
0 Universal Building Set with 4.5v motor Model A
0 !LDRAW_ORG Model
(2019-05-27, 0:47)Victor Di Rienzo Wrote: [ -> ]Looks like is should modify the header as im posting below.
0 FILE 4896 - Roadster Main.ldr
0 Roadster Main
0 Name: 4896 - Roadster Main.ldr
0 Author: Joe Smith [jsmith]
0 !LDRAW_ORG Unofficial_Model
(2019-04-30, 0:43)Victor Di Rienzo Wrote: [ -> ]Set: 8054 - Universal Building Set with 4.5v motor Model B
OMR Compliant: Yes
Missing: Nothing
Comments: none
