Full Version: Technic 1990
Pages: 1 2 3
(2019-04-29, 21:02)Victor Di Rienzo Wrote: [ -> ]Set: 8850 - Rally Support Truck
OMR Compliant: Yes
Missing: Nothing
CAD: LDcad 1.6b As it should be [Image: wink.png]
Comments: none
Sorry, but not OMR compliant.
Here the report from MPD-Center:
Check for: 8850 - Rally Support Truck.ldr
True - Mirrored parts free.
True - All files have correct License.
True - All Name entries are like filename.
True - Is MPD filename OMR conform.
False - All filenames in the MPD are OMR conform.
False - ~Moved to parts free.
False - Unresolved references free.
If some item is not True, you find below the file that causes that.
Error in: '8850 - Rally Support Truck.ldr' Unofficial file figure.ldr needs to be added.
Error in: '8850 - Rally Support Truck.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck.ldr' Filename not OMR conform because of the above error(s).
Error in: '8850 - Rally Support Truck Gearbox.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck Gearbox.ldr' Filename not OMR conform because of the above error(s).
Error in: '8850 - Rally Support Truck chasis.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck chasis.ldr' Filename not OMR conform because of the above error(s).
Error in: '8850 - Rally Support Truck Seat.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck Seat.ldr' Filename not OMR conform because of the above error(s).
Error in: '8850 - Rally Support Truck Engine.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck Engine.ldr' Filename not OMR conform because of the above error(s).
(2019-04-29, 21:00)Victor Di Rienzo Wrote: [ -> ]Set: 8850 - Rally Support Truck - Model B
OMR Compliant: Yes
Missing: Nothing
Comments: none
The same errors here:
Check for: 8850 - Rally Support Truck - Model B.mpd
Error in: '8850 - Rally Support Truck - Model B.ldr' Unofficial file figure.ldr needs to be added.
Error in: '8850 - Rally Support Truck - Model B.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck - Model B.ldr' Filename not OMR conform because of the above error(s).
Error in: '8850 - Rally Support Truck - Model B Front.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck - Model B Front.ldr' Filename not OMR conform because of the above error(s).
Error in: '8850 - Rally Support Truck - Model B motor.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck - Model B motor.ldr' Filename not OMR conform because of the above error(s).
Error in: '8850 - Rally Support Truck - Model B Bumper.ldr' Filename without setnumber does not match file description.
Error in: '8850 - Rally Support Truck - Model B Bumper.ldr' Filename not OMR conform because of the above error(s).
Cleanup and OMRize all four file and add it to the OMR.
Pages: 1 2 3
