Full Version: astromech heads
Given that 30367cps0.dat exists, I'm using its code to work up two additional models, as shown in the attached images.
(Front view):
[attachment=3565]
(Rear view):
[attachment=3566]
I'm posting the MPD file I'm using for my notes, in case any of you would like to look at them.
[attachment=3567]
My question to you all is, do you think these files are ready to be submitted to the Parts Tracker?  ;-)
Thanks,
Franklin
I've updated the MPD file and posted new images.
Here are the files at the Parts Tracker:
Cylinder  2 x  2 with Dome Top with SW Green and Bluish-Grey / R2 Unit Pattern
http://www.ldraw.org/cgi-bin/ptdetail.cg...67cps0.dat
Cylinder  2 x  2 with Dome Top with SW Dark Blue / R2-D2 (2013) Pattern
http://www.ldraw.org/cgi-bin/ptdetail.cg...67cps8.dat
Cylinder  2 x  2 with Dome Top with SW Silver / R4-P17 (2016) Pattern
http://www.ldraw.org/cgi-bin/ptdetail.cg...67cps9.dat
~Dome  2 x  2 with SW Astromech R2/R4 Pattern - Outlines
http://www.ldraw.org/cgi-bin/ptdetail.cg...ps0s01.dat
~Dome  2 x  2 with SW Astromech R2/R4 Pattern - Panels
http://www.ldraw.org/cgi-bin/ptdetail.cg...ps0s02.dat
~Dome  2 x  2 with SW Astromech R2/R4 Pattern - Main Eye, Thick Box, Band at Equator
http://www.ldraw.org/cgi-bin/ptdetail.cg...ps0s03.dat
~Dome  2 x  2 with SW Astromech R2/R4 Pattern - Non-Variable Surfaces
http://www.ldraw.org/cgi-bin/ptdetail.cg...ps0s04.dat
Just as a reminder: If there are any discussions about one or more of this files, these discussions should go to THIS THREAD here at the Forums, instead of at the Parts Tracker.
Thanks!  ;-)
Franklin
Quote:The space in front of each linetype 1 to 5 should be removed.
This is supposed to be a matter of aesthetics.
But in any event, I removed those leading spaces, so the next time I upload any of these files, this won't be a problem any more.
Unofficial File parts/s/30367ps0s02.dat
Quote:Line 27: Colinear vertices found. 3 16 11.5952 2.4257 -7.2717 9.8635 2.4261 -9.8635 12.152 2.4257 -6.4385
Line 28: Colinear vertices found. 3 16 12.8871 2.4258 -5.3382 12.152 2.4257 -6.4385 9.8635 2.4261 -9.8635
Line 29: Colinear vertices found. 3 16 -11.5952 2.4258 7.2718 -9.8636 2.4262 9.8636 -12.1521 2.4258 6.4385
Line 30: Colinear vertices found. 3 16 -9.8636 2.4262 9.8636 -12.8872 2.4259 5.3383 -12.1521 2.4258 6.4385
Please explain this; I don't understand.
Unofficial File parts/s/30367ps0s04.dat
Quote:There is a gap:
2 4 7.4077 11.6787 -17.8825 7.4237 11.958 -17.9209
2 4 7.2482 11.9045 -17.9477 7.4202 11.9623 -17.9221
I don't have ANY lines (red or otherwise) in this subfile.
What are you talking about, please?
Quote:Line 451: Colinear vertices found. 3 16 7.6434 0.3462 4.9903 8.5981 0.3462 3.5618 8.2003 0.3462 4.1571
Line 492: Colinear vertices found. 3 16 6.309 4.686 -15.23 4.945 4.686 -15.5015 4.145 4.686 -15.6608
Unofficial File parts/30367cps8.dat
Unofficial File parts/30367cps9.dat
(Same complaints for both files.)
Quote:Line 39: Flat subfile is scaled in flat direction 1 100 11.5 12.75 15.336 1.33 -0.88 0.131 0 0.235 1.582 -0.89 -1.315 0.195 4-4disc.dat
Line 40: Flat subfile is scaled in flat direction 1 16 11.5 12.75 15.336 1.33 -0.88 0.131 0 0.235 1.582 -0.89 -1.315 0.195 4-4ndis.dat
I'm not sure how that happened. The circle and non-circle were both angled with respect to each axis (x, y, and z), so I had to scale them accordingly.
If you have any suggestions on how to fix this, please let me know.
Thanks!  ;-)
Franklin
(2021-10-08, 10:18)Franklin W. Cain Wrote: [ -> ]Unofficial File parts/s/30367ps0s04.dat
Running a file trough Edger it will find unmatched edges and generate red lines. We usually post those lines in the PT to mark the error. Here's the related gap:
[attachment=6950]
Collinear vertices means that your vertices create a triangle with no "height". See:
[attachment=6951]
(2021-10-08, 10:18)Franklin W. Cain Wrote: [ -> ]Unofficial File parts/30367cps8.dat
Just hit the "Quick fix" button in LDPE. You'll get:
1 100 11.5 12.75 15.336 1.33 0 0.131 0 1 1.582 -0.89 0 0.195 4-4disc.dat
1 16 11.5 12.75 15.336 1.33 0 0.131 0 1 1.582 -0.89 0 0.195 4-4ndis.dat
BTW. 30367cps8 is missing the set reference in the keywords.
(2021-10-08, 10:18)Franklin W. Cain Wrote: [ -> ](Same complaints for both files.)
T-Junk is considered bad stile. Read:
https://wiki.ldraw.org/wiki/T-Junction
LDPE has a fine T-Junction under: Tools -> TJunctionFinder
(2021-10-08, 15:12)Willy Tschager Wrote: [ -> ]T-Junk is considered bad stile. Read:
T junctions aren't just bad style, they are illegal unless justified.
(2021-10-08, 18:18)Orion Pobursky Wrote: [ -> ]T junctions aren't just bad style, they are illegal unless justified.
They trigger a warning, but aren't illegal. See 59:
https://www.ldraw.org/docs-main/ldraw-or...sages.html
(2021-10-08, 19:10)Willy Tschager Wrote: [ -> ]They trigger a warning, but aren't illegal. See 59:
That's basically what I wrote. Warnings need to be justified.
(2021-10-08, 15:03)Willy Tschager Wrote: [ -> ]Just hit the "Quick fix" button in LDPE. You'll get:
I'll include these corrections into my copy of the files.
Thanks!  ;-)
Franklin
(2021-10-08, 15:03)Willy Tschager Wrote: [ -> ]BTW. 30367cps8 is missing the set reference in the keywords.
If I recall correctly, there were way too many sets to list.
Franklin
(2021-10-08, 14:59)Willy Tschager Wrote: [ -> ]Collinear vertices means that your vertices create a triangle with no "height".
If I understand this correctly, I can just remove those offending DAT code lines, yes?
Thanks,
Franklin
(2021-10-08, 14:52)Willy Tschager Wrote: [ -> ]Running a file trough Edger it will find unmatched edges and generate red lines. We usually post those lines in the PT to mark the error.
So, I just add these lines into the file (using a more appropriate color code), correct?
Thanks, again!  ;-)
Franklin
(2021-10-08, 15:12)Willy Tschager Wrote: [ -> ]Read:
OK, _now_ I see what you're talking about!  ^_^
I can fix these.
Willy, thank you for all of your replies and explanations.
Franklin
(2021-10-14, 2:26)Franklin W. Cain Wrote: [ -> ]So, I just add these lines into the file (using a more appropriate color code), correct?
Thanks, again!  ;-)
Franklin
Hi Franklin,
Sorry, I totally missed your questions in the forum regarding my review. Undecided
As most of your questions seems to be solved just a short (or longer) note to this one.
First of all an explanation how I do reviews (the other reviewers might do it a bit different...):
a) open the File with LDDP and get a quick overview, read the header, check the description, the number etcs.
b) searching for real pictures (or grab in my own collection).
c) visual check in LDView (main color, random colour mode, bfc mode), first check for missing edges.
d) run the part through DatHeader and check the errors and warnings in LDView.
e) run the part through Edger2 - (with debug colours, to get unmatched edges, missing edges and missing condlines) Sidenote: unmatched edges is either the open end of a subpart, a gap or a t-junction.
f) open the file generated by Edger2 in LDView and make a visual check, verifiy the added edges and condlines and compare it with the original file in LDView visually.
g) if neccessary open one of both files or both files in LDPE and check the condlines and vertices there.
h) (sometimes I check the complete part in LDPE again (as LDPE has a nixe functions to show the errors and warnings in directly in the workspace))
i) write my review
For finding the gap, you need to add the edges to the file, to see where it is. Then fix the gap (correct corresponding lines and condlines, if neccessary) and delete the inserted lines.
If you have further question feel free to ask. :-)
And thank you very much for fixing the space in front of the codelines.
Best regards
(2021-10-14, 2:23)Franklin W. Cain Wrote: [ -> ]If I recall correctly, there were way too many sets to list.
Franklin
You only need to list one set. It helps in cross referencing to Bricklink, Rebrickable, and other inventory site. I also highly recommend (but it's not required) to have a Bricklink <number> or Rebrickable <number> keyword as well.
(2019-05-12, 13:55)Franklin W. Cain Wrote: [ -> ]~Dome  2 x  2 with SW Astromech R2/R4 Pattern - Outlines
I have uploaded new versions of these four sub-files. I think I've fixed most of the problems with the sub-files (I'm merely 65% certain about sub-file #4, to be honest). If anyone finds any additional (or continued) problems with them, please post details in this thread, and I'll gladly re-investigate.
Thanks, everyone!  ;-)
Franklin
(2021-10-14, 16:33)Franklin W. Cain Wrote: [ -> ]I have uploaded new versions of these four sub-files. I think I've fixed most of the problems with the sub-files (I'm merely 65% certain about sub-file #4, to be honest). If anyone finds any additional (or continued) problems with them, please post details in this thread, and I'll gladly re-investigate.
Franklin
I checked the subfiles now and 3 got a cert vote :-)
As expected subfile 4 still contains some problems.
Please delete the lines 216 and 341 and one of each duplicated lines.
Remove one of the empty lines at the file end.
Trailing zeros are in the lines 208, 213, 335, 338, 347 and 349. It's always the y-value 11.9580
(2021-10-15, 21:11)Max Martin Richter Wrote: [ -> ]I checked the subfiles now and 3 got a cert vote :-)
Thanks, Max.  ;-)
Surplus blank line at end-of-file has been deleted.
Telling me the specific numeric value with the extraneous trailing zero helped me greatly. Since you identified it further by telling me it was the Y-axis component, I knew I could do a simple mass-replace.
I need more details than "line number" (for the "duplicate result" lines), please.  I actually need to see the specific DAT code for the line(s) in question, in order to positively identify it, please. I'm looking for what I think may be these lines, and I'll post some of them here, to ask for more details on the problem(s) cited...
We're getting closer to my goal of adding more astromechs into the LDraw library!  ^_^
Franklin
(2021-10-14, 15:47)Orion Pobursky Wrote: [ -> ]You only need to list one set. It helps in cross referencing to Bricklink, Rebrickable, and other inventory site. I also highly recommend (but it's not required) to have a Bricklink <number> or Rebrickable <number> keyword as well.
OK, going through the list of sets, these are the ones I _know_ I've bought, with the newer R2-D2 "head" (the "full dome" print jobs, as opposed to the first-generation "polar only" print jobs).
0 !KEYWORDS set 7877, set 9493, set 75136, set 75214, set 75228
Thanks,
Franklin
(2021-10-16, 2:38)Franklin W. Cain Wrote: [ -> ]Thanks, Max.  ;-)
Franklin
Here are the duplicated lines (the first and second control point is just switched in the second line, so one of both lines must be removed):
5 24 -8 0 0 -12.593 1.217 0 -8 0 3.314 -7.391 0 -3.062
5 24 -8 0 0 -12.593 1.217 0 -7.391 0 3.062 -8 0 -3.314
5 24 0 0 -8 0 1.217 -12.593 -3.314 0 -8 3.062 0 -7.391
5 24 0 0 -8 0 1.217 -12.593 -3.062 0 -7.391 3.314 0 -8
5 24 0 0 8 0 1.217 12.593 3.314 0 8 -3.062 0 7.391
5 24 0 0 8 0 1.217 12.593 3.062 0 7.391 -3.314 0 8
5 24 8 0 0 12.593 1.217 0 8 0 -3.314 7.391 0 3.062
5 24 8 0 0 12.593 1.217 0 7.391 0 -3.062 8 0 3.314
5 24 -12.593 1.217 0 -16.486 4.686 0 -11.634 1.217 4.819 -12.593 1.217 -5.216
5 24 -12.593 1.217 0 -16.486 4.686 0 -12.593 1.217 5.216 -11.634 1.217 -4.819
5 24 0 1.217 -12.593 0 4.686 -16.486 -5.216 1.217 -12.593 4.819 1.217 -11.634
5 24 0 1.217 -12.593 0 4.686 -16.486 -4.819 1.217 -11.634 5.216 1.217 -12.593
5 24 0 1.217 12.593 0 4.686 16.486 5.216 1.217 12.593 -4.819 1.217 11.634
5 24 0 1.217 12.593 0 4.686 16.486 4.819 1.217 11.634 -5.216 1.217 12.593
5 24 12.593 1.217 0 16.486 4.686 0 11.634 1.217 -4.819 12.593 1.217 5.216
5 24 12.593 1.217 0 16.486 4.686 0 12.593 1.217 -5.216 11.634 1.217 4.819
5 24 -16.486 4.686 0 -19.087 9.876 0 -16.486 4.686 6.828 -15.23 4.686 -6.309
5 24 -16.486 4.686 0 -19.087 9.876 0 -15.23 4.686 6.309 -16.486 4.686 -6.828
5 24 0 4.686 -16.486 0 9.876 -19.087 -6.828 4.686 -16.486 6.309 4.686 -15.23
5 24 0 4.686 -16.486 0 9.876 -19.087 -6.309 4.686 -15.23 6.828 4.686 -16.486
5 24 0 4.686 16.486 0 9.876 19.087 6.828 4.686 16.486 -6.309 4.686 15.23
5 24 0 4.686 16.486 0 9.876 19.087 6.309 4.686 15.23 -6.828 4.686 16.486
5 24 16.486 4.686 0 19.087 9.876 0 15.23 4.686 -6.309 16.486 4.686 6.828
5 24 16.486 4.686 0 19.087 9.876 0 16.486 4.686 -6.828 15.23 4.686 6.309
5 24 -19.087 9.876 0 -20 16 0 -19.087 9.876 7.906 -17.634 9.876 -7.305
5 24 -19.087 9.876 0 -20 16 0 -17.634 9.876 7.305 -19.087 9.876 -7.906
5 24 0 9.876 -19.087 0 16 -20 -7.305 9.876 -17.634 7.906 9.876 -19.087
5 24 0 9.876 -19.087 0 16 -20 -7.906 9.876 -19.087 7.305 9.876 -17.634
5 24 0 9.876 19.087 0 16 20 7.305 9.876 17.634 -7.906 9.876 19.087
5 24 0 9.876 19.087 0 16 20 7.906 9.876 19.087 -7.305 9.876 17.634
5 24 19.087 9.876 0 20 16 0 19.087 9.876 -7.906 17.634 9.876 7.305
5 24 19.087 9.876 0 20 16 0 17.634 9.876 -7.305 19.087 9.876 7.906
I've made all of the corrections requested, and I've uploaded the revised version.
Thanks, again!  ;-)
Franklin
(2019-05-12, 13:55)Franklin W. Cain Wrote: [ -> ]Cylinder  2 x  2 with Dome Top with SW Dark Blue / R2-D2 (2013) Pattern
Trying to find those "T"-junctions...
2 4 11.369 11.168 15.141 12.699 11.168 14.251
2 4 12.961 14.332 14.6415 12.6985 11.168 14.251
2 4 12.961 14.332 14.641 11.631 14.332 15.531
2 4 12.699 11.168 14.251 12.83 12.75 14.446
2 4 12.83 12.75 14.446 12.961 14.332 14.641
2 4 11.631 14.332 15.531 10.301 14.332 16.421
2 4 10.301 14.332 16.421 10.17 12.75 16.226
2 4 10.17 12.75 16.226 10.039 11.168 16.031
2 4 10.3015 14.332 16.421 12.961 14.332 14.6415
2 4 12.6985 11.168 14.251 10.039 11.168 16.0305
2 4 10.039 11.168 16.0305 10.3015 14.332 16.421
2 4 10.039 11.168 16.031 11.369 11.168 15.141
0 // thick-lined box
4 10 13.4478 10.4 13.6205 12.698 11.168 14.251 10.039 11.168 16.030 7.3349 10.4 17.7062
4 11 7.6027 15.1001 18.3540 10.302 14.332 16.421 12.961 14.332 14.642 13.9391 15.1001 14.1192
4 12 7.3349 10.4 17.7062 10.039 11.168 16.030 10.302 14.332 16.421 7.6027 15.1001 18.3540
4 13 12.698 11.168 14.251 13.4478 10.4 13.6205 13.9391 15.1001 14.1192 12.961 14.332 14.642
4 16 7.3349 10.4 17.7062 7.6027 15.1001 18.354 4.9578 15.1 18.8801 4.7829 10.4 18.2138
. . . I don't see any "T"-junctions.  (But I could be blind.)
Please point me in the right direction.
(EDIT)
Playing with the color of those "error" lines shows me that the problem is with the 4-4 non-disc primitive. Since I have fixed the other issue with the non-disc, but have not yet submitted that correction, I believe this correction fixes both issues.
I will re-submit these two files (ps8 and ps9), and then let's test them anew.
Thanks!  ;-)
Franklin
I figured out the "T"-junction issue.   ^_^
For those (like me) who did not understand how this issue occurred in the first place... ;-)
The problem with the 4-4 non-disc was that it was not just one primitive, but rather it was a placeholder for FOUR primitives, with EACH primitive being ONE-QUARTER of a circle/non-disc. Which meant that the MID-POINTS (i.e. the center point of each of the larger square's four lines) was actually an endpoint for two of the primitives, resulting in the "T"-junctions.
The More We Know! ^_^
Uploaded corrected versions of the two files in question.
Currently, these two files are being held over an issue regarding Color Code(s).  I'd be grateful if an Admin could wade in and resolve these questions, please.
Thanks!  ^_^
Franklin
If any one out there would like to take over fixing these new files, please GO FOR IT!!  ^_^
My only objective with tis project was to give me and other modelers the ability to more accurately depict the multiple variants of droids in the Star Wars universe. Unfortunately, over the years, it seems that my abilities (such as they were) as a coder have been eclipsed by the more modern capabilities of the more recent tools that have come about.
And if you'd rather tackle some astromech heads from scratch, there's a huge backlog of as-yet unclaimed projects waiting to be grabbed: https://forums.ldraw.org/thread-25495.html
Thank you!  ;-)
Franklin
Ref: https://ldraw.org/cgi-bin/ptdetail.cgi?f...67cps8.dat
Orion, Magnus, THANK YOU BOTH, for fixing (Orion) and reviewing (Magnus) this file.  ^_^
If at all possible, I would dearly love to have this part (regardless of whether with or without its "sister" parts) released this year. I'd consider that to be an awesome Christmas present for me!  ;-)
Thanks, again!
Franklin
Line type 5 is an optional line (condline). The generic format is:
5 <colour> x1 y1 z1 x2 y2 z2 x3 y3 z3 x4 y4 z4
In the image below are A B C D, where the condline is A-B and the control point are C and D.
The control points are made visible by lines between A, C and D.
[attachment=8620]
The condline in the image have one bad control point, D
Control point D needs to be changed and use vertex E, or F instead.
(2022-11-03, 20:22)Magnus Forsberg Wrote: [ -> ]The condline in the image have one bad control point, D
Your explanation along with the image helped me to understand what you meant. Thank you, sir.  ;-)
Unfortunately, since I did not actually write the original LDraw code for those cond-lines --(after all, I just recycled the code that John Troxler [Gargan] wrote for 30367cps0.dat)-- I am not certain that I will be able to do a proper job of fixing these defects.
I hate to impose upon you, but I am wondering if you would mind fixing these problematic cond-lines, please. I would consider this to be a great favor to me. And if I am out of line asking for this, please accept my apologies for my imposition.
Thank you,
Franklin
(2022-11-04, 2:33)Franklin W. Cain Wrote: [ -> ]... I am wondering if you would mind fixing these problematic cond-lines
Done.
https://www.ldraw.org/cgi-bin/ptdetail.c...ps0s04.dat
(2022-11-05, 10:41)Magnus Forsberg Wrote: [ -> ]Done.
Thank you!  ^_^
Franklin
I've updated 30367cps9 per Magnus' latest advice. Hopefully, these changes will get the job done.
https://www.ldraw.org/cgi-bin/ptdetail.c...67cps9.dat
Thanks!  ;-)
Franklin
I need a consensus, please, on how to proceed with this file on the Tracker:
Unofficial File parts/30367cps0.dat
https://library.ldraw.org/parts/24426
I have stated previously that I did not consider my work to be a "complete rewrite" since it was technically just a re-organization of Gargan's original DAT code. However, with the need for updating to the newer License Agreement, others have stated (on the PT) that my work would qualify as a rewrite (if I understand those comments correctly).
Given the existing DAT code as it currently stands on the PT, what changes (if any) would I need to make to this specific DAT file, to qualify as a legitimate rewrite, in order to proceed with the approval process, without being an act of plagiarism, in the consensus of our community, please?
Thank you,
Franklin
(PS: On my copy of this DAT file on my PC's hard drive, I've already made some minor updates to the Keywords. But this is totally separate from the issue I'm raising in this post. Nonetheless, I've attached a copy of this latest version here, in case it matters.)
(PPS: I would be comfortable with the phrase "partial rewrite" for my work on this DAT file. Would that be acceptable, for taking charge of this file and updating the Author and License tags accordingly?)
i completely rewrote the part from scratch with some code take from 38367cps8.dat
wonder different it is compared to the one on the tracker
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\30367cs01.dat
1 71 0 0 0 1 0 0 0 1 0 0 0 1 s\30367ps0s01.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\30367ps0s02.dat
1 2 0 0 0 1 0 0 0 1 0 0 0 1 s\30367ps0s03.dat
1 16 0 0 0 1 0 0 0 1 0 0 0 1 s\30367ps0s04.dat
4 322 -8.1727 11.7 -17.3751 -9.2421 11.7 -16.6603 -9.277 12.2 -16.725 -8.2034 12.2 -17.4425
4 322 -8.2955 13.7 -17.645 -9.3814 13.7 -16.9191 -9.4164 14.2 -16.9838 -8.3262 14.2 -17.7124
1 16 0 19.3 0 20 0 0 0 0.7 0 0 0 20 4-4cyli.dat
1 16 0 16 0 -7.653669 0 -18.477591 0 0.7 0 18.477591 0 -7.653669 3-4cyli.dat
3 322 .5985 11.3732 -19.1912 1.8077 11.1602 -18.9189 1.1786 11.128 -19.0392
4 322 2.3897 11.4646 -18.8485 1.8077 11.1602 -18.9189 .5985 11.3732 -19.1912 .1557 11.8586 -19.3516
4 322 2.8365 11.9954 -18.8388 2.3897 11.4646 -18.8485 .1557 11.8586 -19.3516 0 12.2845 -19.4461
3 322 2.4013 14.5267 -19.3027 1.1922 14.7399 -19.575 1.8212 14.7719 -19.4547
4 322 .6101 14.4353 -19.6454 1.1922 14.7399 -19.575 2.4013 14.5267 -19.3027 2.8441 14.0413 -19.1423
4 322 .6101 14.4353 -19.6454 2.8441 14.0413 -19.1423 3.0823 13.3898 -18.9978 .1634 13.9045 -19.6551
4 322 .1634 13.9045 -19.6551 3.0823 13.3898 -18.9978 3.0797 12.6715 -18.8912 0 13.4503 -19.6199
3 322 3.0797 12.6715 -18.8912 -.0798 13.2285 -19.5712 0 13.4503 -19.6199
3 322 -.0798 13.2285 -19.5712 3.0797 12.6715 -18.8912 -.0825 12.5101 -19.4635
3 322 -.0825 12.5101 -19.4635 3.0797 12.6715 -18.8912 2.8365 11.9954 -18.8388
3 322 -.0825 12.5101 -19.4635 2.8365 11.9954 -18.8388 0 12.2845 -19.4461
4 0 -7.145 11.9501 17.975 -7.1999 12.9501 18.1132 -7.4802 12.9501 18.0577 -7.4232 11.95 17.9198
4 0 -7.4232 11.95 17.9198 -7.4802 12.9501 18.0577 -13.8203 12.95 13.8203 -13.7148 11.95 13.7148
4 0 -13.9922 11.95 13.2997 -13.7148 11.95 13.7148 -13.8203 12.95 13.8203 -14.0997 12.95 13.4021
1 322 11.5 12.75 15.336 1.33 0 0.131 0 1 1.582 -0.89 0 0.195 4-4disc.dat
3 16 13.4478 10.4 13.6205 12.699 11.168 14.251 11.369 11.168 15.141
3 16 13.4478 10.4 13.6205 11.369 11.168 15.141 7.3349 10.4 17.7062
3 16 7.3349 10.4 17.7062 11.369 11.168 15.141 10.039 11.168 16.031
3 16 13.4478 10.4 13.6205 12.83 12.75 14.446 12.699 11.168 14.251
3 16 13.9391 15.1001 14.1192 12.83 12.75 14.446 13.4478 10.4 13.6205
3 16 12.83 12.75 14.446 13.9391 15.1001 14.1192 12.961 14.332 14.641
3 16 11.631 14.332 15.531 12.961 14.332 14.641 13.9391 15.1001 14.1192
3 16 11.631 14.332 15.531 13.9391 15.1001 14.1192 10.301 14.332 16.421
3 16 10.301 14.332 16.421 13.9391 15.1001 14.1192 7.6027 15.1001 18.354
3 16 10.17 12.75 16.226 10.301 14.332 16.421 7.6027 15.1001 18.354
3 16 10.17 12.75 16.226 7.6027 15.1001 18.354 10.039 11.168 16.031
3 16 10.039 11.168 16.031 7.6027 15.1001 18.354 7.3349 10.4 17.7062
3 16 7.3349 10.4 17.7062 7.6027 15.1001 18.354 4.9578 15.1 18.8801
3 16 7.3349 10.4 17.7062 4.9578 15.1 18.8801 4.7829 10.4 18.2138
Per the PT policies and FAQs, a rewrite is done from scratch and without referring to the original file's code. I leave what that means up to the individual authors.
I'll also note that this is a part fix so a license update is desired but not required. I'll ask Takeshi to lift his hold.
Sorry to bother, but does anyone have a flat pattern of the 30361 astromech pattern?  Just trying to get something nice to use for a print/decal.
