Full Version: Cable WeDo 2.0 LS06a.dat
I need a cable as in the attachment: LEGO |WeDo 2.0. part no. LS06a.dat (LSynth Constraint Part - Typ 6a - „Power Functions WeDo 2.0 Cable").
Does anyone have this part or know where to find it?
Thx in advance!
(2019-04-06, 8:59)Piter Wrote: [ -> ]Hi,
Welcome here, Piter!
You can find this constraint in this archive file: http://jc-tchang.philohome.com/manuel/Im...xemple.zip
It comes from this excellent lsynth3 tutorial (in French): http://jc-tchang.philohome.com/manuel/Lsynth3.htm
You can also try to use LDCad which includes a powerful flexible parts generator (including Wedo 2.0 elements)...
(2019-04-07, 16:00)Philippe Hurbain Wrote: [ -> ]Welcome here, Piter!
Thank you for your help![Image: thumbsup.png][Image: smile.png]
(2019-04-08, 9:53)Piter Wrote: [ -> ]Thank you for your help![Image: thumbsup.png][Image: smile.png]
I added LSynth Constraint - LS06a.dat to MLCad / Lsynth. I can see this part on the list, but when I try to use
ELECTRIC POWER FUNCTIONS CABLE it becomes "hidden". Pls look at the screen. Manual change of the status to "unhide" doesn't help. BTW, when I used another part- LS06.dat it worked fine (the cable was rendered). Do you know what's the problem ?
(2019-04-08, 20:06)Piter Wrote: [ -> ]I added LSynth Constraint - LS06a.dat to MLCad / Lsynth. I can see this part on the list, but when I try to use
I suspect that files have to be changed and made to fit. mlcad.ini, lsynth.mpd, ....
(2019-04-09, 19:24)Johann Eisner Wrote: [ -> ]I suspect that files have to be changed and made to fit. mlcad.ini, lsynth.mpd, ....
Thx for your help!
I've updated the files mlcad.ini again.
I have new function now (ELECTRIC_POWER_FUNCTIONS_WEDO2_CABLE 16). It works [Image: smile.png]
