Hi
Before LDCad has created the image structure of the model, all parts are displayed with a green cross.
Is a part in the library not available with a red cross.
Is it possible to switch back so that you can only see the crosses again?
Regards Johann
Current cross colors are:
Green: Still loading/prepping
Red: Part not found
Yellow: Render prep failed
There is no option to view the crosses after stuff has been loaded/prepped but it is possible you'll see the crosses again later on when a loaded files has been changed outside of LDCad.
Curious: Why do you want to bring back the crosses?
(2019-03-04, 20:41)Johann Eisner Wrote: [ -> ]Hi
Regards Johann
I suppose you could delete (or just move, for a reversible effect) the folder containing your parts library.
(2019-03-04, 22:41)Roland Melkert Wrote: [ -> ]Curious: Why do you want to bring back the crosses?
Hi Roland
For the following reason:
I am still from the old school (MLCad), and there it is, if one opens a model and parts are missing, there is an error message.
Eg: Part xyz.dat not found, should the loading of the model be prefixed?
So I know immediately that something is wrong with the model.
At LDCad there are just red crosses to see.
If I now examine a model for the OMR, I see at LDCad immediately, if something is wrong. That is the reason.
Maybe you could install an error message for the next version of LDCad, because once the model is loaded,
you can not tell if something is missing.
Regards from rainy Austria
Johann
(2019-03-05, 19:33)Johann Eisner Wrote: [ -> ]I am still from the old school (MLCad), and there it is, if one opens a model and parts are missing, there is an error message.
I always found that extremely annoying when like 100 parts are missing. So I disabled it by default in my own program
But you can enable it if you want
prefs/ldraw/report missing files
Or inspect it at anytime for the current model
session/missing files
(2019-03-05, 19:38)Roland Melkert Wrote: [ -> ]I always found that extremely annoying when like 100 parts are missing. So I disabled it by default in my own program
Perfect.
Thanks.
That helps me tremendously.
