Full Version: Star Wars Technic
Star Wars Technic figures (2000-2002)
[Image: 8001.jpg]
Download MPD (OMR compliant)
Known errors: None.
Done with LDCad 1.6b
Rendered with Studio 2.0
[Image: 8001_-_battle_droid_-_at-st.jpg]
Known errors: None.
An interesting B-model... Good usage of parts, same theme but very different from main model, looks good (OK, would be better in grey instead of tan!).
(2019-02-10, 10:38)Philippe Hurbain Wrote: [ -> ]An interesting B-model... Good usage of parts, same theme but very different from main model, looks good (OK, would be better in grey instead of tan!).
I never knew that this one had a B-model, but right, this is a very interesting one!
[Image: 8012.jpg]
Known errors: None.
[Image: 8002.jpg]
Known errors: None.
This one was tough to model (and probably to build in physical world too...). If we ever get a LEGO mechanical simulator, the unfolding sequence (https://www.youtube.com/watch?v=WiMF-ubjvjA) is going to be a challenge...
(2019-02-19, 10:49)Philippe Hurbain Wrote: [ -> ]This one was tough to model (and probably to build in physical world too...). If we ever get a LEGO mechanical simulator, the unfolding sequence (https://www.youtube.com/watch?v=WiMF-ubjvjA) is going to be a challenge...
Nothing a couple of hundred lua lines couldn't do Big Grin
nitpick: you can clearly see you used LQ rigid hoses.
(2019-02-19, 19:09)Roland Melkert Wrote: [ -> ]Nothing a couple of hundred lua lines couldn't do  Big Grin
For sure Wink
Quote:nitpick: you can clearly see you used LQ rigid hoses.
No choice to use Studio2 renderer. Actually the render looks worse than what we see with LDView or LDCad (the mpd was saved with a lower resolution than the one used for the render).
(2019-02-10, 10:32)Philippe Hurbain Wrote: [ -> ]Download MPD (OMR compliant)
Known errors: None.
Hi Philo
Wrong file link.
You linked to the .jpg.
Johann
LOL. I never got my physical model to work properly...
(2019-02-10, 10:29)Philippe Hurbain Wrote: [ -> ]Star Wars Technic figures (2000-2002)
Unfortunately not yet in the OMR.
Because there are upload errors.
Already contacted Merlijn.
Sorry, forgot this... link now updated!
