2019-01-29, 12:43
I want to render part transparent with black line ,but the line can not show a Correct color with black line when the parts overlap.I tried everything I could ,but didn`t work[attachment=3399]
(2019-01-29, 12:43)HWQ Wrote: [ -> ]I want to render part transparent with black line ,but the line can not show a Correct color with black line when the parts overlap.I tried everything I could ,but didn`t work
(2019-01-30, 8:27)Jaco van der Molen Wrote: [ -> ](2019-01-29, 12:43)HWQ Wrote: [ -> ]I want to render part transparent with black line ,but the line can not show a Correct color with black line when the parts overlap.I tried everything I could ,but didn`t work
I think this is not possible since the lines are rendered transparent too.
I guess you have modified the line color in the ldconfig.ldr file?
These parts are not placed correct and should not overlap.
Jaco
Thx your reply
As you might guess,i had modified all the transparent corlor with the line color #333333 in ldconfig.ldr . But here are not correct display.
As follows,I bulid a model transparent and solid plastic color.And I don`t think it is displayed correctly at my mark.I want it look like the picture 2.
(2019-01-30, 11:04)HWQ Wrote: [ -> ](2019-01-30, 8:27)Jaco van der Molen Wrote: [ -> ]Hi,
Jaco
Thx your reply
(2019-01-30, 14:32)Jaco van der Molen Wrote: [ -> ]Ah, OK. I see what you mean.
Still, I do not think that is possible in LDraw / LDView, since parts behind transparent parts are rendered like this and transparant lines are rendered slightly transparent too.
(2019-02-01, 20:57)Johann Eisner Wrote: [ -> ]Hi
Just played a little bit with LDview.
Maybe that's the solution.
J.
