The release candidate of the AIOI 2018-02 can be downloaded here:
http://www.holly-wood.it/tmp/LDraw_AIOI_...bit_v1.exe
Change log:
* Update to Parts Library 2018-02
* Update to MLCad.ini 2018-02
* Update to LPub3D 2.3.6 (since this requires Visual C++ Redistributable Packages for Visual Studio 2015 the AIOI will check if the runtime is installed and otherwise install it)
* Update to Offline Parts Catalog 2018-02
* Update to LDFind 1.3.5.4
* Update toMPDCenter 2.5.0.0
Your testing would be appreciated.
(2019-01-28, 13:27)Willy Tschager Wrote: [ -> ]Your testing would be appreciated.
So I decided to hit the reset button on my Windows box Ldraw install. Everything is good. A couple small nits:
- The 64 bit versions of both LDCad and LDView are not installed.
- The unofficial path is not set for any programs despite the fact that the unofficial folder exists.
(2019-01-29, 5:15)Orion Pobursky Wrote: [ -> ]- The 64 bit versions of both LDCad and LDView are not installed.
To offer both versions the AIOI requires a major overhaul - if I can find the time.
The unofficial folder is not set on
purpose.
(2019-01-29, 19:53)Willy Tschager Wrote: [ -> ] (2019-01-29, 5:15)Orion Pobursky Wrote: [ -> ]- The 64 bit versions of both LDCad and LDView are not installed.
The unofficial folder is not set on purpose.
Ok Cool. I figured. Everything else worked great.
(2019-01-28, 13:27)Willy Tschager Wrote: [ -> ]Hi,
Change log:
I only tested the parts lib: seems to works like a charm.
sorry, not closely related, but related:
the announcement of the availability of MLCad.ini 2018-02 is missing on our main page ldraw.org.
there only MLCad.ini 2018-01 is announced.
Made a Harakiri action and installed complete new.
Works fine, the only thing i saw is
that in the unofficial folder the "p" folder isn't installed automaticly.
Only a small problem, because by installing the unofficial parts from PT the folder is created.
JE.
