(2019-01-22, 15:36)Orion Pobursky Wrote: [ -> ]You rock. Thanks. Are there typeface primitives for the Architecture tiles? If so, I can do this myself in the future.
No there are none. But I have some doubts concerning usefulness. txt2dat works fine and allows kerning, something impossible with predefined boxed primitives.
(2019-01-22, 17:58)Orion Pobursky Wrote: [ -> ]What’s the font again?
Here I used plain old Arial... Myriad Web Pro is not bad either.
(2019-01-22, 17:03)Philippe Hurbain Wrote: [ -> ] (2019-01-22, 15:36)Orion Pobursky Wrote: [ -> ]You rock. Thanks. Are there typeface primitives for the Architecture tiles? If so, I can do this myself in the future.
Good point regarding kerning. Do you think the Swiss721BT primitives are overkill? Would it be better (although WET, not DRY *) to inline, as been done with text representations many times elsewhere?
WET vs. DRY
(2019-01-22, 19:25)Chris Dee Wrote: [ -> ]Good point regarding kerning. Do you think the Swiss721BT primitives are overkill? Would it be better (although WET, not DRY *) to inline, as been done with text representations many times elsewhere?
* WET vs. DRY
For me yes, they are overkill. Considering the gazillon of available fonts, it's often easier to use a similar font, generate the text with txt2dat and if needed tweak a few letter shapes to better match the font used by LEGO (and even if the font was available as primitives, tweaking it implies inlining...)
(2019-01-23, 12:23)Philippe Hurbain Wrote: [ -> ] (2019-01-22, 19:25)Chris Dee Wrote: [ -> ]Good point regarding kerning. Do you think the Swiss721BT primitives are overkill? Would it be better (although WET, not DRY *) to inline, as been done with text representations many times elsewhere?
* WET vs. DRY
It's not Ariel or Myriad .... I hope you do not mind, Phillip
The font for this part is again Swiss BT 721 .... but not "bold" .... in that case it is "normal".
...fits 100%
A real proof that this font has been in use since the gray 12v era until today at Lego.
Perhaps the trade off should be to introduce only very commonly used fonts as primitives.
... makes sense anyway in frequent occurrences .. otherwise Phillip, of course you have legitimate good arguments.
(2019-01-25, 15:35)Ulrich Röder Wrote: [ -> ] (2019-01-23, 12:23)Philippe Hurbain Wrote: [ -> ]For me yes, they are overkill. Considering the gazillon of available fonts, it's often easier to use a similar font, generate the text with txt2dat and if needed tweak a few letter shapes to better match the font used by LEGO (and even if the font was available as primitives, tweaking it implies inlining...)
...fits 100%
I've not created many textual patterned parts myself, but I'd like to understand the relative development effort and rendering efficiency between a) building the text string with txt2dat and tweaking if necessary, versus b) scaling and combining individual character primitives.
Thanks,
(2019-01-25, 15:48)Chris Dee Wrote: [ -> ]... I'd like to understand the relative development effort and rendering efficiency between a) building the text string with txt2dat and tweaking if necessary, versus b) scaling and combining individual character primitives.
I would say that the difference is not that great.
The difficulty lays in finding the correct, and free of charge, font, downloading it and tweeking the settings in txt2dat.
Once you have a good set of low enough resolution letters in a file, I import it into LPC and scale and resize it to fit the text in the sticker I'm working on. I tend to remove the four corners from the txt2dat file, and reuse/reshape the rest, to minimize the vertices.
For sure, having a character primitive might speed things up, but only if it was already created. And then I would have to inline them to simplify the mesh, removing unnecessary vertices. The benefit of using txt2dat is that the triangulation between the letters is already done. Using inlined character prims might force a complete recreation of the background surface. OTOH sometimes you want a vertex between (or above and below) the letters to avoid thin, long triangles. But that is easy to add in LPC.
