2018-11-06, 19:57
Hi all,
A while ago I posted this thread:
https://forums.ldraw.org/thread-17401.html
Now I am struggling with the annotation for Technic Beams.
I haven't got a clue how to write a regular expression, so is there anyone here who can?
What I am aiming at is that the length of beams is annotated for beams of length 3 or longer and not the lift arms or bent beams.
[Edit]: and including the half or thin beams, but not the modified ones.
Thanks in advance!
[Edit]
Here is the list I want the length to be annotated:
32523.dat Technic Beam 3
32316.dat Technic Beam 5
32017.dat Technic Beam 5 x 0.5
32063.dat Technic Beam 6 x 0.5
32524.dat Technic Beam 7
32065.dat Technic Beam 7 x 0.5
40490.dat Technic Beam 9
32525.dat Technic Beam 11
41239.dat Technic Beam 13
32278.dat Technic Beam 15
No annotation needed for:
18654.dat Technic Beam 1
41672.dat Technic Beam 1 x 3 x 7 with 4 Axleholes and 3 Holes
41665.dat Technic Beam 1 x 4 x 7 with 5 Axleholes and 2 Holes and 1 Slot
43857.dat Technic Beam 2
60483.dat Technic Beam 2 Liftarm
50923.dat Technic Beam 2 Liftarm with Angled Ball Joint
64276.dat Technic Beam 2 Liftarm with Straight Ball Joint
85940.dat Technic Beam 2 with Angled Bar
41677.dat Technic Beam 2 x 0.5 Liftarm
32140.dat Technic Beam 2 x 4 Liftarm Bent 90
50904.dat Technic Beam 2 x 8 x 2 Double Liftarm with 2 1 x 3 Beams
98577.dat Technic Beam 3 with Integrated Ball Joint
61071.dat Technic Beam 3 with Panel Fairing Left
61070.dat Technic Beam 3 with Panel Fairing Right
44225.dat Technic Beam 3 with Rotation Joint 3 Pin
44224.dat Technic Beam 3 with Rotation Joint 3 Socket
6632.dat Technic Beam 3 x 0.5 Liftarm
33299.dat Technic Beam 3 x 0.5 Liftarm with Boss and Pin
60484.dat Technic Beam 3 x 3 T-shaped
32056.dat Technic Beam 3 x 3 x 0.5 Liftarm Bent 90
32249.dat Technic Beam 3 x 3 x 0.5 Liftarm Bent 90 Quarter Circle
32009.dat Technic Beam 3 x 3.8 x 7 Liftarm Bent 45 Double
32526.dat Technic Beam 3 x 5 Bent 90
32250.dat Technic Beam 3 x 5 x 0.5 Liftarm Bent 90 Quarter Ellipse
32271.dat Technic Beam 3 x 7 Liftarm Bent 53.13
45803.dat Technic Beam 3 x 7 x 3 Bent 90 Double Chamfered
41681.dat Technic Beam 3.8 x 1 Liftarm with Click Rotation Ring Socket
32449.dat Technic Beam 4 x 0.5 Liftarm
2825.dat Technic Beam 4 x 0.5 Liftarm with Boss
41679.dat Technic Beam 4 x 0.5 Liftarm with Click Rotation Hinge Half
43464.dat Technic Beam 4 x 3 Liftarm Triangle
32348.dat Technic Beam 4 x 4 Liftarm Bent 53.13
6629.dat Technic Beam 4 x 6 Liftarm Bent 53.13
11478.dat Technic Beam 5 x 0.5 Liftarm with Axle Holes at Both Ends
14720.dat Technic Beam 5 x 3 H-shaped
2905.dat Technic Beam 5 x 3 x 0.5 Liftarm Triangle
99773.dat Technic Beam 5 x 3 x 0.5 Liftarm Triangle Type 2
32251.dat Technic Beam 5 x 7 x 0.5 Liftarm Bent 90 Quarter Ellipse
32311.dat Technic Beam 7 Offset Liftarm with 24 Tooth Gears
32177.dat Technic Beam 7 x 1 Liftarm with Ribs and Fan
32308.dat Technic Beam 7 x 3 x 2 Liftarm Split
64179.dat Technic Beam 7 x 5 with Open Center 5 x 3
32079.dat Technic Beam 9 Liftarm Offset with Boss
64178.dat Technic Beam 11 x 5 with Open Center 5 x 3
Thanks in advance!
[Edit]
