guys while i was making the building isntruction of a model. and im using a wedo motor. i use the "flexible motor" and make the cable get inserted into the hub.
i was wondering if there is any way to keep the cable unplugged on the building instructions until a specific step. and then plug the cable. its to avoid having the cable hiding some parts of the model.
(2018-10-17, 23:03)tatubias Wrote: [ -> ]guys while i was making the building isntruction of a model. and im using a wedo motor. i use the "flexible motor" and make the cable get inserted into the hub.
Buffer exchange won't work unless there is only one or a few step(s) between temporary and final placement.
The easiest way is probably by using two parts, one normal motor and a template with only the cable part. You can then use those in different steps.
Hi
In MLCaD/LPub3D this function works with "Group" and "Remove Group".
It does not matter how many steps are in between.
Regards Johann
(2018-10-19, 13:09)Johann Eisner Wrote: [ -> ]Hi
Regards Johann
Looks like this, for example....
