2018-09-28, 10:56
guys i was wondering if someone could let me knwo if there is any way not to overlap the rubberbands in ldca when they are in a crossing section
0 FILE main.ldr
1 71 0 0 -50 0 0 -1 0 1 0 1 0 0 4185b.dat
1 71 0 0 90 0 0 -1 0 1 0 1 0 0 4185b.dat
1 4 0 0 -50 0 0 -1 0 1 0 1 0 0 rubberBandRound-1.ldr
0 FILE rubberBandRound-1.ldr
0 Author: LDCad
0 !CATEGORY technic
0 !KEYWORDS flexible, band
0 !LDCAD CONTENT [type=path] [addFallBack=default] [looped=true] [displayKind=mm] [curveStep=0] [displayLenCor=0]
0 !LDCAD PATH_POINT [type=circle] [posOri=0 0 0 1 0 0 0 1 0 0 0 1] [prevCPDist=25] [nextCPDist=25] [cirR=30] [cirDir=xyCW] [prevYRoll=0] [nextYRoll=0]
0 !LDCAD PATH_POINT [type=bezier] [posOri=70 0 2 -0.469472 -0.882948 0 0.882948 -0.469472 0 0 0 1] [prevCPDist=16.5] [nextCPDist=14.5] [cirR=30] [cirDir=xyCW] [prevYRoll=0] [nextYRoll=0]
0 !LDCAD PATH_POINT [type=circle] [posOri=140 0 0 1 0 0 0 1 0 0 0 1] [prevCPDist=25] [nextCPDist=25] [cirR=30] [cirDir=xyCCW] [prevYRoll=0] [nextYRoll=0]
0 !LDCAD PATH_POINT [type=bezier] [posOri=70 0 -2 -0.469472 0.882948 0 -0.882948 -0.469472 0 0 0 1] [prevCPDist=16] [nextCPDist=16.5] [cirR=30] [cirDir=xyCW] [prevYRoll=0] [nextYRoll=0]
0 !LDCAD PATH_SKIN [donCol=16] [donOri=1 0 0 0 1 0 0 0 1] [donPart=ldcRubberBandRndSeg.dat] [donYSize=400%] [donCen=absCen] [donCenYOfs=0] [donFinScale=fitDon2Seg] [donPlace=deform] [donYAlign=0] [donInline=false] [segSize=100%] [segSizeTol=5%] [segsCnt=0] [segsGrp=0] [segsMaxMerge=10] [segsMrgAng=0] [segsMrgRollAng=0] [segsEdgeDelKind=keepFirstLeft]
(2018-09-28, 12:39)Philippe Hurbain Wrote: [ -> ]First, instead of turning the second control point 180° it is better to change properties of this control point from clockwise to counter clockwise. This avoids the squishing effect you have. Then to avoid the overlap at crossing, you need to add two bezier control points and place/orient them as needed. Here is an example:
Code:0 FILE main.ldr
0 Author: LDCad
0 !CATEGORY technic
(2018-09-28, 14:21)tatubias Wrote: [ -> ](2018-09-28, 12:39)Philippe Hurbain Wrote: [ -> ]First, instead of turning the second control point 180° it is better to change properties of this control point from clockwise to counter clockwise. This avoids the squishing effect you have. Then to avoid the overlap at crossing, you need to add two bezier control points and place/orient them as needed. Here is an example:
0 Author: LDCad
0 !CATEGORY technic
Thank you very very much!!!!!!
ldcad rocks
(2018-09-28, 15:31)Philippe Hurbain Wrote: [ -> ]You have to keep an eye on order of control points. Use the source window for this !
(2018-09-28, 17:37)tatubias Wrote: [ -> ]i did play little longer , what i have to say about ldcad, its by far the more flexible and complete Lego CAD software.Yeah! one more converted guy
its not the most easy to learn but has the most advance features out there.
tatubias Wrote:im trying to add the second bezier but it allways put it on the same side of the rubber, i did try to add it in the other side and allways it adds it on the same place. probably im missing somethingNew path points are always added after the current selected one if possible.
(2018-09-28, 17:37)tatubias Wrote: [ -> ]i did play little longer , what i have to say about ldcad, its by far the more flexible and complete Lego CAD software.Thanks, I've always targeted LDCad at the more advanced / larger model creating crowd.
the only missing things that i had in mind the developer already has in his pipe line.
congratulations
(2018-09-28, 18:34)Philippe Hurbain Wrote: [ -> ]Yeah! one more converted guy
