When I try to open LDraw on the latest version of Windows 7, this error appears:
"The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher."
Any help? (I'm a 64-bit user.)
Many thanks.
(2018-08-31, 21:32)Christian Murray Wrote: [ -> ]When I try to open LDraw on the latest version of Windows 7, this error appears:
Many thanks.
Are talking about the LDraw All-In-One installer or a single program.
(2018-09-01, 10:07)Willy Tschager Wrote: [ -> ] (2018-08-31, 21:32)Christian Murray Wrote: [ -> ]When I try to open LDraw on the latest version of Windows 7, this error appears:
Many thanks.
I'm talking about the All-In-One installer.
(2018-09-01, 20:39)Christian Murray Wrote: [ -> ] (2018-09-01, 10:07)Willy Tschager Wrote: [ -> ]Are talking about the LDraw All-In-One installer or a single program.
The current AIOI is a 32bit-only installer. Do you have a folder called c:\windows\LDraw on your system?
Hi Christian,
32 bit programs should run just fine on 64 bit Windows so there’s something weird going on. Can you do a couple troubleshooting steps for me? First, delete the AIOI exe and redownload it. See if that works, sometimes this error is caused by a corrupted download. Second, if it’s still not working, right click on the the file and choose “Run as Adminstrator”. That may work as well.
Press the windows key + R and type in winver. Post a screenshot of the the popping up dialog.
(2018-09-03, 3:29)Orion Pobursky Wrote: [ -> ]Ok, I can confirm that the AIOI installer on our servers is corrupt. This is probably the cause of your error. Until I get our file fixed, please use the mirror at 1000stiene:
https://www.1000steine.de/downloads/LDra...bit_v2.exe
And now our file is good. Both download links should give you a working file.
