2018-08-13, 21:17
I've made a new primitive, hipstud.dat to be used on all the differently shaped hips available as LDD files.
[attachment=3245]
I want to create more hips, like the genie-hip and the ghost-hip. In fact, I already have them prepared and want to upload them.
[attachment=3245]
- Does the name work? hipstud.dat
When do I have to also create a lo-res version? Isn't that only needed to fool MLCad?
- There is sometime a small difference of the inner diameter of the hipstud. Some hipstuds seem to have a blocked inside.
It is oddly shaped and nothing connects to that hole. Is it OK to only have one version of the hipstud?
- I remember a discusion about the tiny hole on the frontside of the stud on short hips and leg, 41879a and 41879b.
IMO one version is missing, 41879c, with blocked hole. The printed short legs also have a difference in the small hole, blocked or open. Do we need to make all these as correct as possible, or is it enough to only use one hipsstud? Which one? I need to create subfiles without printed surface.
- There is a subfile for the two-coloured short leg, with shorts (Bart Simpson), but now there is a new version of the two-coloured part for Dobby. New partnumber and new subfiles?
