2018-08-09, 22:18
Hey,
I think Willy had to wait far too long for this
Changelog:
(3 new features and 2 bug fixes)
What will the next release 0.8.46 deliver? clever auto-completion / context menu for the text editor / usability.
System Requirements:
Minimum System Requirements:
Changelog:
- ...directly set the render mode (via GUI toolbar and shortkeys, Alt + NUMPAD + 1 to 9)
- ...set the viewport perspective (via GUI toolbar and shortkeys, Ctrl + NUMPAD + 8,4,5,6,2,0)
- ...close the view (via GUI toolbar and shortkey, Q)
- The vertex window stayed on top of all open programs.
- [OpenGL 2.0 only] TEXMAP with transparency did not show the expected result.
- Download the zip-Archive
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
