Hi all,
I wanted to upload a model I made. I am totally new to this, so any feedback is more than welcome.
Best regards,
Charles
Hi Charles,
welcome to this forum and congratulation for submitting a model which is OMR compliant. I'd like to point out just one thing. According to the
Official Model Repository (OMR) Specification Version 1.0.3 the optional qualifier was the wrong choice:
The
<Optional Qualifier>
is not mandatory and gets added only if there is more than one set that could be assigned the same
. The first set using a given number would be understood to never contain the qualifier however numbering should start with the oldest set and some investigation should be done in existing set databases.
Example:
6901 - Mobile Lab.mpd (Produced in 1980)
6901-2 - Space Plane.mpd (Produced in 1998)
The correct naming of the MPD would be: 8022 - TECHNIC Starter Set - Plane.mpd
See:
For playsets or other sets where there are multiple models that are part of an integral whole, all of the submodels will be contained in one MPD.
Example:
The creator set 4896 - Roaring Roadsters has 3 models in the instructions:
4896 - Roaring Roadsters - Roadster.mpd
4896 - Roaring Roadsters - Dragster.mpd
4896 - Roaring Roadsters - SUV.mpd
Hi Willy,
Thanks for pointing that out. I thought the optional qualifier was meant for submodels, but I was wrong
One question: Do I need to finish the other submodels before this one will be uploaded?
In this particular case, I want to finish the other submodels anyway, but I am just wondering because for some set the submodels can't really bother me.
I am a bit confused by the fact that "for playsets or other sets where there are multiple models that are part of an integral whole, all of the submodels will be contained in one MPD." If I look at the existing models, the submodels are always seperate files, e.g.,
http://omr.ldraw.org/set/850-1/. Is it just that for uploading, all the submodels are part of one MPD file, while they might appear on the website as different MPD files?
Best regards!
Charles
(2018-08-05, 5:19)Charles Farmer Wrote: [ -> ]One question: Do I need to finish the other submodels before this one will be uploaded?
No. The real question is why aren't there any new uploads since Dec. 28, 2017? I'll have to investigate?
(2018-08-05, 5:19)Charles Farmer Wrote: [ -> ]I am a bit confused by the fact that "for playsets or other sets where there are multiple models that are part of an integral whole, all of the submodels will be contained in one MPD." If I look at the existing models, the submodels are always seperate files, e.g., http://omr.ldraw.org/set/850-1/. Is it just that for uploading, all the submodels are part of one MPD file, while they might appear on the website as different MPD files?
Scratch that. Nobody ever did it and we should rather change the rule than the other way around.
Instead of putting all the submodels in one MPD file, I also made four seperate files, consistent with other examples (e.g., see
http://omr.ldraw.org/set/850-1/). For uploading, one can decide what is of best use.
Of course, if there are some issues with the models I created, please let me know.
Best regards,
Charles
