2018-07-04, 16:43
sorry, the last release had a bug. It's fixed now.
Changelog:
(0 new features and 1 bug fixes)
With this release the following critical issue is fixed:
When you install/extract LDPE on Windows you will find your LDPE configuration files under
{drive}\Users\{user}\AppData\Roaming\LDPartEditor
It is not recommended to use the "update.bat" script when you installed LDPE via the setup file.
Manually install the new version instead.
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
Changelog:
- Clicking on the tabs no longer changed the 3D view. / Scrolling in the text editor didn't refresh line numbers.
- Download the zip-Archive
- On windows, double-click "LDPartEditor.exe" to start LDPE.
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
