Hello -
First post here, I believe I looked in all the places I could to be sure that the part I am seeking isn't already catalogued.
The part I would like to request:
93561 - Minifig, Visor Hockey Mask
I did find this part in Lego Digital Designer and have exported the .ldr file (attached) but do not see the part in MLCad or LDraw. I am also fairly technical and would feel comfortable authoring this part if someone could point me in the right direction.
Thank you!
Jodi Rehlander
(2018-07-02, 4:19)Jodi Rehlander Wrote: [ -> ]I did find this part in Lego Digital Designer and have exported the .ldr file (attached) but do not see the part in MLCad or LDraw. I am also fairly technical and would feel comfortable authoring this part if someone could point me in the right direction.
Welcome here Jodi!
Hockey mask doesn't indeed exist in LDraw library. So your LDD export contains nothing, only parts existing in both systems gets translated, if the parts mapping file (ldraw.xml) contains the appropriate entry (see
https://www.eurobricks.com/forum/index.p...sion-file/)
That said, a raw conversion of LDD part does exist:
http://www.digital-bricks.de/en/file.php?part=93561
It needs to be cleaned, and its compatibility with matching helmet must be checked. Then it can be submitted to LDraw Parts Tracker
(2018-07-02, 13:03)Philippe Hurbain Wrote: [ -> ] (2018-07-02, 4:19)Jodi Rehlander Wrote: [ -> ]I did find this part in Lego Digital Designer and have exported the .ldr file (attached) but do not see the part in MLCad or LDraw. I am also fairly technical and would feel comfortable authoring this part if someone could point me in the right direction.
That said, a raw conversion of LDD part does exist: http://www.digital-bricks.de/en/file.php?part=93561
Thank you! I found the helmet at that website as well and I am on my way to getting them both submitted!
