2018-07-01, 20:55
Hey,
after all these business trips I found some time for a new release :D
Changelog:
(4 new features and 1 bug fixes)
When you install/extract LDPE on Windows you will find your LDPE configuration files under
{drive}\Users\{user}\AppData\Roaming\LDPartEditor
It is not recommended to use the "update.bat" script when you installed LDPE via the setup file.
Manually install the new version instead.
Please note that this software is in the beta stage. Although, this version was tested, there are already known issues for this release. There is a potential risk of data loss.
System Requirements:
Minimum System Requirements:
Changelog:
- ...translate the 3D view by just moving the cursor to the border of the 3D view (open the options menu to enable this).
- ...use a vertex window in the top right corner to show/modify the x, y, z values of a single selected vertex.
- ...see the transformation delta info placed right after the cursor coordinates on the status bar.
- ...benefit from an enhanced "BFC + TEXMAP / Materials" render mode (OpenGL 3.3 only)
- The context menu button was invisible when rulers were shown on the 3D view.
- Download the zip-Archive
- On windows, double-click "LDPartEditor.exe" to start LDPE.
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
java -d64 version
