Full Version: Neu Bugatti Technic Parts
Pages: 1 2
37383: Wheels 62.3X42 37383 (DXF will follow)
https://m.rebrickable.com/media/cache/69...4bf5f9.jpg
35189: Brake Disc
https://m.rebrickable.com/media/cache/4e...f4abb0.jpg
35185: ANGLED GEAR WHEEL Z20 (Combination of 18575 and 18946)
https://m.rebrickable.com/media/cache/b7...3b9305.jpg
98138pr0039 Tile Round 1 x 1 with Bugatti Logo print
https://m.rebrickable.com/media/cache/6b...0cdac6.jpg
35188 GEAR SHIFTER, W/ CROSS HOLE
https://m.rebrickable.com/media/cache/a7...6d0c89.jpg
35186: Technic Driving Ring Extension 8 Tooth
https://m.rebrickable.com/media/cache/c0...44418c.jpg
(2018-06-07, 19:34)Thorsten Wrote: [ -> ]37383: Wheels 62.3X42 37383 (DXF will follow)
http://www.ldraw.org/cgi-bin/ptdetail.cg.../35185.dat Wink
Wow... that was really fast. Thanks
(2018-06-07, 20:01)Thorsten Wrote: [ -> ]Wow... that was really fast. Thanks
No rocket science, I started before you asked Big Grin  (https://www.eurobricks.com/forum/index.p...w-library/)
BTW, could you get me photos of the rotary chageover (top/bottom/right/front)? There are many available on the web, but nothing in cartesian directions... And side photo of brake disc (with thickness)
[quote='Philippe Hurbain' pid='28806' dateline='1528459252']
Extension ring done: [url=http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/35186.dat]http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/35186.d
Thanks
Wheel dxf is not complet:
https://bricksafe.com/files/Thorsten50/wheels.dxf
The bracke-Photo comes in a moment
35189: Brake Disc
Front
D outside 42,5mm  height 1,5mm
D ring 24mm  height 4mm
D Pin out- 8mm and inside 5mm height 6mm
behind
D 22x0,5
DXF
https://bricksafe.com/files/Thorsten50/Brake%20Disk.dxf
(2018-06-09, 19:59)Thorsten Wrote: [ -> ]
(2018-06-08, 12:00)Philippe Hurbain Wrote: [ -> ]Extension ring done: [url=http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/35186.dat]http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/35186.d
Thanks
Great, Thanks! I'll keep you in touch if I miss something for these parts. What about rotary changeover?
(2018-06-09, 20:34)Thorsten Wrote: [ -> ]35189: Brake Disc
Done! http://www.ldraw.org/cgi-bin/ptdetail.cg.../35189.dat
I am missing some depth measurements...
- Distance between pins supporting disc (base of pins) and back of rim?
- Distance between front stud base and front of rim? And more generally, distance between the various elements of center 5 branch star and front of wheel.
Pages: 1 2
