Hi All,
finally decided to migrate to LPub3D, but having some issues with new parts.
They appear on the rendered model, but they won't appear on the Parts list, any help will be appreciated
The part I'm missing is 25269.
my root library is my Stud.io root library, haven't had any issues with part till this one
(2018-04-18, 22:40)Paco Wrote: [ -> ]Hi All,
Hi Paco,
the corner tile (25269) is currently an unofficial LDraw part i.e. it is found in the unofficial library. I'm assuming that it in the studio library. I would suggest trying the following;
Does the value for LPub3D's "LDraw Content Search Directories" (look for this in the "Other" tabbed sheet when the menu item Configuration/Preferences is selected) contain the library path to wherever you have got the studio library located? If your answer is "no", add it, exit LPub3D, run LPub3D again, open your model and reset all cache (menu item Tools/Reset Cache/Reset All Caches).
If the answer to #1 was "yes" or it was "no" and the suggested steps did not resolve the issue, I don't have a suggested resolution. While I use LPub3D, I don't use studio as my modelling tool but LDCad instead. So my suggestion is an educated guess only.
Please reply to this message and indicate whether or not the suggestion resolves your issue so that other users of studio may know whether or not to try the suggestion.
Regards,
David
LPub3D uses its own parts libraries which are located at:
C:\Users\[username]\AppData\Local\LPub3D\data
or
C:\Users\[merlijn]\AppData\Local\LPub3D Software\LPub3D\libraries
depending on your LPub3D version.
You have to add the missing part to lpub3dldrawunf.zip or just replace the whole zip file with the newest zip from here:
http://www.ldraw.org/library/unofficial/ldrawunf.zip
Make sure to rename the zip file to lpub3dldrawunf.zip.
However, LPub3D also has a built-in tool to update the parts. Under Tools -> Refresh LDraw Unofficial parts.
In older versions of LPub3D it didn't work very well (for me at least). I have no idea if it was fixed in the recent updates, but I recommend to only use this feature if you have the newest version of LPub3D.
Hope that helps
(2018-04-19, 18:56)Merlijn Wissink Wrote: [ -> ]LPub3D uses its own parts libraries which are located at:
or
You have to add the missing part to lpub3dldrawunf.zip or just replace the whole zip file with the newest zip from here: http://www.ldraw.org/library/unofficial/ldrawunf.zip
Hope that helps
I had the same issue with the same part. I have updated the unofficial part list, but now LDGLite keeps crashing...
Any tips?
(2018-06-18, 19:21)Zoltan Markella Wrote: [ -> ]I had the same issue with the same part. I have updated the unofficial part list, but now LDGLite keeps crashing...
Any tips?
Sounds stupid perhaps, but to solve it, do not use LDGLite. Though fast and still functioning LDGLite is a bit outdated and not quite up to date.
Try LDView as renderer. Nearly as fast, if not faster and better quality images.
